[gdal-dev] Code reformatting applied
    Kurt Schwehr
    schwehr at gmail.com
    Sat Dec 17 13:24:33 PST 2022
Woohoo!  Thanks!
On Sat, Dec 17, 2022 at 1:20 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> The code reformatting has now landed into master and release/3.6
> branches per pull requests https://github.com/OSGeo/gdal/pull/6937 and
> https://github.com/OSGeo/gdal/pull/6939. I've applied it now since the
> number of opened pull requests is low. I've split the reformatting in
> one commit per modified directory, to avoid potential issues with UI
> like github that could have performance issues with a single huge commit.
> For developers, when you'll have resynchronized your local copy with
> master, do the following from the top of your clone so that commits with
> code reformatting are ignored when using "git blame"
> git config blame.ignoreRevsFile .git-blame-ignore-revs
> This is documented in
> https://gdal.org/development/dev_practices.html#blame-ignore-file
> If you have ongoing work in local branches not sent as PR, and that you
> intend to submit as a single-commit (or squashed as a single-commit on
> merging), do *not* merge master into it, otherwise you'll get conflicts.
> But you can apply the following workflow to reformat your modified files
> to comply with the formatting rules:
> git fetch upstream master # assuming 'upstream' points to OSGeo/gdal
> git checkout -b reformatted_branch  # to not mess up with your original
> work
> git cherry-pick 5d80bc1 2796f2a b9c28a1 3103e5e 48c9ea8cb4  # to fetch
> modified pre-commit hook and .clang-format
> pip install pre-commit # if not already done
> pre-commit install # if not already done
> pre-commit run --files foo/bar.cpp bar/baz.h  # put here the list of
> your modified files to reformat
> Copy all your modified files as .cpp.new / .h.new ones for example
> Create a new branch from latest master and copy the .cpp.new / .h.new
> files on top of the .cpp / .h ones (or use a merge tool if there have
> been conflicting changes in between to only merge your changes)
> If you want your work to be merged as multiple commits, then I'm afraid
> you'll have to endure some pain to create copies of modified files by
> each commit in their before and after state, reformat those different
> versions, generate patches with the diff between the reformated
> before/after versions, and use those diffs with git apply to recreate
> commits in a new branch on top of latest master
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221217/eda1d565/attachment.htm>
