[gdal-dev] std::numeric_limits<int64_t>::min() vs LLONG_MIN
Even Rouault
even.rouault at spatialys.com
Sun Dec 18 13:59:56 PST 2022
Paul,
I've queued your proposed fix in pull request
https://github.com/OSGeo/gdal/pull/6943
Even
Le 18/12/2022 à 22:18, Paul Meems a écrit :
> I made the brackets bold. That seems to result in the *
> Only ( and ) are needed, no *.
> Regards,
> Paul
> Op zo 18 dec. 2022 18:39 schreef Andrew C Aitchison
> <andrew at aitchison.me.uk>:
> On Sun, 18 Dec 2022, Paul Meems wrote:
> > Thanks all for your suggestions.
> > I did some more research and it seems to be an issue with the
> preprocessor
> > on Windows.
> > Adding some brackets solves the issue as well:
> > // old
> > constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
> > std::numeric_limits<int64_t>::min();
> > constexpr uint64_tGDAL_PAM_DEFAULT_NODATA_VALUE_UINT64=
> > std::numeric_limits<uint64_t>::max();
> > // new:
> > constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =*(*
> > std::numeric_limits<int64_t>::min*)*();
> > constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =*(*
> > std::numeric_limits<uint64_t>::max*)*();
> Do you mean to add *(* and *)* or just ( and ) ?
> > I'm not sure what the impact would be for non-windows compilers,
> but if no
> > impact could this be changed in the code?
> > Thanks,
> > Paul Meems
> > Op za 17 dec. 2022 om 07:10 schreef <dg0yt at darc.de>:
> >> I'm not using MSVC, so this is a guess:
> >> Are you including 'windows.h' without 'NOMINMAX' being defined?
> >> Then you will get macros which interfere with the limits code.
> >> Regards, Kai.
> >>> Paul Meems <bontepaarden at gmail.com> hat am 17.12.2022 00:46 CET
> >> geschrieben:
> >>> Thanks, Kurt for your response.
> >>> I'm getting a very vague error message:
> >>> E0040 expected an identifier.
> >>> Regards,
> >>> Paul
> >>> Op za 17 dec. 2022 om 00:40 schreef Kurt Schwehr
> <schwehr at gmail.com>:
> >>>> What exact error are you getting?
> >>>> On Fri, Dec 16, 2022 at 3:31 PM Paul Meems
> >> wrote:
> >>>>> Hello List,
> >>>>> We're trying to update MapWinGIS which is using the GDAL
> libraries
> >> from gisinternals.com <http://gisinternals.com>
> (http://gisinternals.com)
> >>>>> Currently, we use the stable daily of December
> >> 9: release-1928-gdal-3-5-mapserver-8-0
> >>>>> I'm using VS2019 (on Windows) to compile and I'm having
> issues with
> >> two lines in gdal_pam.h, around line 215.
> >>>>> We need to change these two lines:
> >>>>> * constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
> >>>>> * constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =
> >>>>> To
> >> LLONG_MIN;
> >> LLONG_MAX;
> >>>>> I prefer not to alter the files from gisinternals.com
> <http://gisinternals.com> (
> >> http://gisinternals.com). Is this what we can solve on our end?
> >>>>> Is it related to the C++ version? We use these:
> >>>>> * ISO C++14 Standard (/std:c++14)
> >>>>> * ISO C11 Standard (/std:c11)
> >>>>> Thanks for any advice.
> >>>>> Paul Meems
> >>>>> _______________________________________________
> >>>>> gdal-dev mailing list
> >>>>> gdal-dev at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Andrew C. Aitchison Kendal, UK
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221218/34d48096/attachment-0001.htm>
