[gdal-dev] std::numeric_limits<int64_t>::min() vs LLONG_MIN
Paul Meems bontepaarden at gmail.com
Sun Dec 18 23:40:14 PST 2022
Thank you Even.
Paul
Op zo 18 dec. 2022 om 22:59 schreef Even Rouault <even.rouault at spatialys.com
> Paul,
> I've queued your proposed fix in pull request
> https://github.com/OSGeo/gdal/pull/6943
> Even
> Le 18/12/2022 à 22:18, Paul Meems a écrit :
> I made the brackets bold. That seems to result in the *
> Only ( and ) are needed, no *.
> Regards,
> Paul
> Op zo 18 dec. 2022 18:39 schreef Andrew C Aitchison <
> andrew at aitchison.me.uk>:
>> On Sun, 18 Dec 2022, Paul Meems wrote:
>> > Thanks all for your suggestions.
>> > I did some more research and it seems to be an issue with the
>> preprocessor
>> > on Windows.
>> > Adding some brackets solves the issue as well:
>> > // old
>> > constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
>> > std::numeric_limits<int64_t>::min();
>> > constexpr uint64_tGDAL_PAM_DEFAULT_NODATA_VALUE_UINT64=
>> > std::numeric_limits<uint64_t>::max();
>> > // new:
>> > constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =*(*
>> > std::numeric_limits<int64_t>::min*)*();
>> > constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =*(*
>> > std::numeric_limits<uint64_t>::max*)*();
>> Do you mean to add *(* and *)* or just ( and ) ?
>> > I'm not sure what the impact would be for non-windows compilers, but if
>> no
>> > impact could this be changed in the code?
>> > Thanks,
>> > Paul Meems
>> > Op za 17 dec. 2022 om 07:10 schreef <dg0yt at darc.de>:
>> >> I'm not using MSVC, so this is a guess:
>> >> Are you including 'windows.h' without 'NOMINMAX' being defined?
>> >> Then you will get macros which interfere with the limits code.
>> >> Regards, Kai.
>> >>> Paul Meems <bontepaarden at gmail.com> hat am 17.12.2022 00:46 CET
>> >> geschrieben:
>> >>> Thanks, Kurt for your response.
>> >>> I'm getting a very vague error message:
>> >>> E0040 expected an identifier.
>> >>>  Regards,
>> >>> Paul
>> >>> Op za 17 dec. 2022 om 00:40 schreef Kurt Schwehr <schwehr at gmail.com>:
>> >>>> What exact error are you getting?
>> >>>> On Fri, Dec 16, 2022 at 3:31 PM Paul Meems <bontepaarden at gmail.com>
>> >> wrote:
>> >>>>> Hello List,
>> >>>>> We're trying to update MapWinGIS which is using the GDAL libraries
>> >> from gisinternals.com (http://gisinternals.com)
>> >>>>> Currently, we use the stable daily of December
>> >> 9: release-1928-gdal-3-5-mapserver-8-0
>> >>>>> I'm using VS2019 (on Windows) to compile and I'm having issues with
>> >> two lines in gdal_pam.h, around line 215.
>> >>>>> We need to change these two lines:
>> >>>>>   * constexpr int64_t GDAL_PAM_DEFAULT_NODATA_VALUE_INT64 =
>> >>>>>   * constexpr uint64_t GDAL_PAM_DEFAULT_NODATA_VALUE_UINT64 =
>> >>>>> To
>> >> LLONG_MIN;
>> >> LLONG_MAX;
>> >>>>> I prefer not to alter the files from gisinternals.com (
>> >> http://gisinternals.com). Is this what we can solve on our end?
>> >>>>> Is it related to the C++ version? We use these:
>> >>>>>   * ISO C++14 Standard (/std:c++14)
>> >>>>>   * ISO C11 Standard (/std:c11)
>> >>>>> Thanks for any advice.
>> >>>>> Paul Meems
>> >>>>> _______________________________________________
>> >>>>>  gdal-dev mailing list
>> >>>>>  gdal-dev at lists.osgeo.org
>> >>>>>  https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Andrew C. Aitchison                      Kendal, UK
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221219/32810c71/attachment.htm>
