[gdal-dev] Tolerance Condition Error ogr2ogr Albers to EPSG:4326
Peter Townsend
peter.townsend at maplarge.com
Mon Dec 19 10:59:45 PST 2022
I figured out that the dataset is actually the "trees" shapefile from the
QGIS sample dataset. Throws the same messaging out.
https://download.qgis.org/downloads/data/
qgis_sample_data\shapefiles\trees.*
Good luck!
On Mon, Dec 19, 2022 at 12:46 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Peter,
> I suspect the reprojection of your features went fine, otherwise you would
> have got an error message like "Failed to reproject feature XXXX (geometry
> probably out of source or destination SRS)". This error message must come
> from some code that tries heuristics related to polar or anti-meridian
> geometry splitting, although normally there are provisions to silent
> non-critical reprojection errors related to those heuristics, but perhaps
> there's some silencing missing somewhere.
> I could have a look if you can pass on the dataset (you can send it / a
> link for it privately if needed)
> Even
> Le 19/12/2022 à 19:16, Peter Townsend via gdal-dev a écrit :
> I've got this test dataset of a bunch of forest areas in Alaska. The
> shapefile is in Albers, and we're converting it to EPSG:4326 lat longs.
> Layer name: trees
> Geometry: Polygon
> Feature Count: 444
> Extent: (-2175230.041280, 1899842.624457) - (4895522.387686,
> 6909266.538422)
> Layer SRS WKT:
> PROJCRS["Albers",
> BASEGEOGCRS["NAD27",
> DATUM["North American Datum 1927",
> ELLIPSOID["Clarke 1866",6378206.4,294.978698213898,
> LENGTHUNIT["metre",1]],
> ID["EPSG",6267]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["Degree",0.0174532925199433]]],
> CONVERSION["unnamed",
> METHOD["Albers Equal Area",
> ID["EPSG",9822]],
> PARAMETER["Latitude of false origin",50,
> ANGLEUNIT["Degree",0.0174532925199433],
> ID["EPSG",8821]],
> PARAMETER["Longitude of false origin",-154,
> ID["EPSG",8822]],
> PARAMETER["Latitude of 1st standard parallel",55,
> ID["EPSG",8823]],
> PARAMETER["Latitude of 2nd standard parallel",65,
> ID["EPSG",8824]],
> PARAMETER["Easting at false origin",0,
> LENGTHUNIT["US survey foot",0.304800609601219],
> ID["EPSG",8826]],
> PARAMETER["Northing at false origin",0,
> ID["EPSG",8827]]],
> CS[Cartesian,2],
> AXIS["(E)",east,
> ORDER[1],
> LENGTHUNIT["US survey foot",0.304800609601219,
> ID["EPSG",9003]]],
> AXIS["(N)",north,
> ORDER[2],
> ID["EPSG",9003]]]]
> We're trying to upgrade our GDAL from 3.21 to 3.53, and our poor test is
> getting flagged now with either "ERROR 1: Point outside of projection
> domain" and/or "ERROR 1: tolerance condition error".
> This is what I'm seeing:
> ogr2ogr.exe -skipfailures -t_srs EPSG:4326 --debug on c:\path\output
> c:\path\trees.shp
> GDAL: GDALOpen(c:\path\trees.shp, this=0000027A1189CBE0) succeeds as ESRI
> Shapefile.
> GDAL: Using ESRI Shapefile driver
> GDAL: GDALDriver::Create(ESRI
> Shapefile,c:\path\output,0,0,0,Unknown,0000000000000000)
> Shape: DBF Codepage = LDID/87 for c:\path\trees.shp
> Shape: Treating as encoding 'ISO-8859-1'.
> GDALVectorTranslate: 444 features written in layer 'trees'
> Shape: 444 features read on layer 'trees'.
> GDAL: GDALClose(c:\path\trees.shp, this=0000027A1189CBE0)
> GDAL: GDALClose(c:\path\output, this=0000027A1189D4A0)
> GDAL: In GDALDestroy - unloading GDAL shared library.
> (Same thing happens without skipfailures.)
> Now I'm 95% sure it's throwing this error because there's some vertex
> somewhere in here that's in that special "dead zone" for Alaska Albers that
> can't convert to 4326 (seen this before on other datasets trying to project
> individual points).
> What I'm wondering is this:
> 1) Is there any way to get GDAL to tell me what feature/coordinate threw
> the error?
> 2) What is it doing as a fallback behavior? Skipping the point and moving
> on? I still come out with the same number of features in the end.
> Thanks!
> Peter Townsend
> Senior Software Developer
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Peter Townsend
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221219/4b63c43f/attachment-0001.htm>
