[gdal-dev] Tolerance Condition Error ogr2ogr Albers to EPSG:4326
Even Rouault
even.rouault at spatialys.com
Mon Dec 19 11:42:00 PST 2022
Fix in https://github.com/OSGeo/gdal/pull/6945. The error is actually
harmless as I suspected and was related to the polar geometry splitting
heuristics not properly shutting off reprojection errors.
Even
Le 19/12/2022 à 19:59, Peter Townsend a écrit :
> I figured out that the dataset is actually the "trees" shapefile from
> the QGIS sample dataset. Throws the same messaging out.
> https://download.qgis.org/downloads/data/
> qgis_sample_data\shapefiles\trees.*
> Good luck!
> On Mon, Dec 19, 2022 at 12:46 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Peter,
> I suspect the reprojection of your features went fine, otherwise
> you would have got an error message like "Failed to reproject
> feature XXXX (geometry probably out of source or destination
> SRS)". This error message must come from some code that tries
> heuristics related to polar or anti-meridian geometry splitting,
> although normally there are provisions to silent non-critical
> reprojection errors related to those heuristics, but perhaps
> there's some silencing missing somewhere.
> I could have a look if you can pass on the dataset (you can send
> it / a link for it privately if needed)
> Even
> Le 19/12/2022 à 19:16, Peter Townsend via gdal-dev a écrit :
>> I've got this test dataset of a bunch of forest areas in Alaska.
>> The shapefile is in Albers, and we're converting it to EPSG:4326
>> lat longs.
>> Layer name: trees
>> Geometry: Polygon
>> Feature Count: 444
>> Extent: (-2175230.041280, 1899842.624457) - (4895522.387686,
>> 6909266.538422)
>> Layer SRS WKT:
>> PROJCRS["Albers",
>> BASEGEOGCRS["NAD27",
>> DATUM["North American Datum 1927",
>> ELLIPSOID["Clarke 1866",6378206.4,294.978698213898,
>> LENGTHUNIT["metre",1]],
>> ID["EPSG",6267]],
>> PRIMEM["Greenwich",0,
>> ANGLEUNIT["Degree",0.0174532925199433]]],
>> CONVERSION["unnamed",
>> METHOD["Albers Equal Area",
>> ID["EPSG",9822]],
>> PARAMETER["Latitude of false origin",50,
>> ANGLEUNIT["Degree",0.0174532925199433],
>> ID["EPSG",8821]],
>> PARAMETER["Longitude of false origin",-154,
>> ID["EPSG",8822]],
>> PARAMETER["Latitude of 1st standard parallel",55,
>> ID["EPSG",8823]],
>> PARAMETER["Latitude of 2nd standard parallel",65,
>> ID["EPSG",8824]],
>> PARAMETER["Easting at false origin",0,
>> LENGTHUNIT["US survey foot",0.304800609601219],
>> ID["EPSG",8826]],
>> PARAMETER["Northing at false origin",0,
>> ID["EPSG",8827]]],
>> CS[Cartesian,2],
>> AXIS["(E)",east,
>> ORDER[1],
>> LENGTHUNIT["US survey foot",0.304800609601219,
>> ID["EPSG",9003]]],
>> AXIS["(N)",north,
>> ORDER[2],
>> ID["EPSG",9003]]]]
>> We're trying to upgrade our GDAL from 3.21 to 3.53, and our poor
>> test is getting flagged now with either "ERROR 1: Point outside
>> of projection domain" and/or "ERROR 1: tolerance condition error".
>> This is what I'm seeing:
>> ogr2ogr.exe -skipfailures -t_srs EPSG:4326 --debug on
>> c:\path\output c:\path\trees.shp
>> GDAL: GDALOpen(c:\path\trees.shp, this=0000027A1189CBE0) succeeds
>> as ESRI Shapefile.
>> GDAL: Using ESRI Shapefile driver
>> GDAL: GDALDriver::Create(ESRI
>> Shapefile,c:\path\output,0,0,0,Unknown,0000000000000000)
>> Shape: DBF Codepage = LDID/87 for c:\path\trees.shp
>> Shape: Treating as encoding 'ISO-8859-1'.
>> GDALVectorTranslate: 444 features written in layer 'trees'
>> Shape: 444 features read on layer 'trees'.
>> GDAL: GDALClose(c:\path\trees.shp, this=0000027A1189CBE0)
>> GDAL: GDALClose(c:\path\output, this=0000027A1189D4A0)
>> GDAL: In GDALDestroy - unloading GDAL shared library.
>> (Same thing happens without skipfailures.)
>> Now I'm 95% sure it's throwing this error because there's some
>> vertex somewhere in here that's in that special "dead zone" for
>> Alaska Albers that can't convert to 4326 (seen this before on
>> other datasets trying to project individual points).
>> What I'm wondering is this:
>> 1) Is there any way to get GDAL to tell me what
>> feature/coordinate threw the error?
>> 2) What is it doing as a fallback behavior? Skipping the point
>> and moving on? I still come out with the same number of features
>> in the end.
>> Thanks!
>> Peter Townsend
>> Senior Software Developer
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Peter Townsend
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221219/48995b27/attachment.htm>
