[gdal-dev] Tolerance Condition Error ogr2ogr Albers to EPSG:4326
Peter Townsend peter.townsend at maplarge.com
Mon Dec 19 11:48:30 PST 2022
Thanks!
One more question. For the time being, is it generally ok to ignore
"tolerance condition error" and "Point outside of projection domain"? I can
make our program not care about those if it's usually harmless.
On Mon, Dec 19, 2022 at 1:42 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Fix in https://github.com/OSGeo/gdal/pull/6945. The error is actually
> harmless as I suspected and was related to the polar geometry splitting
> heuristics not properly shutting off reprojection errors.
> Even
> Le 19/12/2022 à 19:59, Peter Townsend a écrit :
> I figured out that the dataset is actually the "trees" shapefile from the
> QGIS sample dataset. Throws the same messaging out.
> https://download.qgis.org/downloads/data/
> qgis_sample_data\shapefiles\trees.*
> Good luck!
> On Mon, Dec 19, 2022 at 12:46 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Peter,
>> I suspect the reprojection of your features went fine, otherwise you
>> would have got an error message like "Failed to reproject feature XXXX
>> (geometry probably out of source or destination SRS)". This error message
>> must come from some code that tries heuristics related to polar or
>> anti-meridian geometry splitting, although normally there are provisions to
>> silent non-critical reprojection errors related to those heuristics, but
>> perhaps there's some silencing missing somewhere.
>> I could have a look if you can pass on the dataset (you can send it / a
>> link for it privately if needed)
>> Even
>> Le 19/12/2022 à 19:16, Peter Townsend via gdal-dev a écrit :
>> I've got this test dataset of a bunch of forest areas in Alaska. The
>> shapefile is in Albers, and we're converting it to EPSG:4326 lat longs.
>> Layer name: trees
>> Geometry: Polygon
>> Feature Count: 444
>> Extent: (-2175230.041280, 1899842.624457) - (4895522.387686,
>> 6909266.538422)
>> Layer SRS WKT:
>> PROJCRS["Albers",
>>     BASEGEOGCRS["NAD27",
>>         DATUM["North American Datum 1927",
>>             ELLIPSOID["Clarke 1866",6378206.4,294.978698213898,
>>                 LENGTHUNIT["metre",1]],
>>             ID["EPSG",6267]],
>>         PRIMEM["Greenwich",0,
>>             ANGLEUNIT["Degree",0.0174532925199433]]],
>>     CONVERSION["unnamed",
>>         METHOD["Albers Equal Area",
>>             ID["EPSG",9822]],
>>         PARAMETER["Latitude of false origin",50,
>>             ANGLEUNIT["Degree",0.0174532925199433],
>>             ID["EPSG",8821]],
>>         PARAMETER["Longitude of false origin",-154,
>>             ID["EPSG",8822]],
>>         PARAMETER["Latitude of 1st standard parallel",55,
>>             ID["EPSG",8823]],
>>         PARAMETER["Latitude of 2nd standard parallel",65,
>>             ID["EPSG",8824]],
>>         PARAMETER["Easting at false origin",0,
>>             LENGTHUNIT["US survey foot",0.304800609601219],
>>             ID["EPSG",8826]],
>>         PARAMETER["Northing at false origin",0,
>>             ID["EPSG",8827]]],
>>     CS[Cartesian,2],
>>         AXIS["(E)",east,
>>             ORDER[1],
>>             LENGTHUNIT["US survey foot",0.304800609601219,
>>                 ID["EPSG",9003]]],
>>         AXIS["(N)",north,
>>             ORDER[2],
>>                 ID["EPSG",9003]]]]
>> We're trying to upgrade our GDAL from 3.21 to 3.53, and our poor test is
>> getting flagged now with either "ERROR 1: Point outside of projection
>> domain" and/or "ERROR 1: tolerance condition error".
>> This is what I'm seeing:
>> ogr2ogr.exe -skipfailures -t_srs EPSG:4326 --debug on c:\path\output
>> c:\path\trees.shp
>> GDAL: GDALOpen(c:\path\trees.shp, this=0000027A1189CBE0) succeeds as ESRI
>> Shapefile.
>> GDAL: Using ESRI Shapefile driver
>> GDAL: GDALDriver::Create(ESRI
>> Shapefile,c:\path\output,0,0,0,Unknown,0000000000000000)
>> Shape: DBF Codepage = LDID/87 for c:\path\trees.shp
>> Shape: Treating as encoding 'ISO-8859-1'.
>> GDALVectorTranslate: 444 features written in layer 'trees'
>> Shape: 444 features read on layer 'trees'.
>> GDAL: GDALClose(c:\path\trees.shp, this=0000027A1189CBE0)
>> GDAL: GDALClose(c:\path\output, this=0000027A1189D4A0)
>> GDAL: In GDALDestroy - unloading GDAL shared library.
>> (Same thing happens without skipfailures.)
>> Now I'm 95% sure it's throwing this error because there's some vertex
>> somewhere in here that's in that special "dead zone" for Alaska Albers that
>> can't convert to 4326 (seen this before on other datasets trying to project
>> individual points).
>> What I'm wondering is this:
>> 1) Is there any way to get GDAL to tell me what feature/coordinate threw
>> the error?
>> 2) What is it doing as a fallback behavior? Skipping the point and moving
>> on? I still come out with the same number of features in the end.
>> Thanks!
>> Peter Townsend
>> Senior Software Developer
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Peter Townsend
Peter Townsend
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221219/71f6dfcd/attachment-0001.htm>
