[gdal-dev] Tolerance Condition Error ogr2ogr Albers to EPSG:4326
Even Rouault even.rouault at spatialys.com
Mon Dec 19 11:56:10 PST 2022
Le 19/12/2022 à 20:48, Peter Townsend a écrit :
> Thanks!
> One more question. For the time being, is it generally ok to ignore
> "tolerance condition error" and "Point outside of projection domain"?
> I can make our program not care about those if it's usually harmless.
They could still be emitted if features' geometries fail to reproject.
If you don't pass the -skip_failure flag, then you can just test ogr2ogr
error code. If it is 0, everything is fine.
http://www.spatialys.com
