[gdal-dev] Error using gdalinfo v 3.5.0 for jp2 (Sentinel-2) data on LINUX
Even Rouault even.rouault at spatialys.com
Sun Dec 25 05:49:12 PST 2022
> Is not  gdal v 3.5.0 supposed to read SENTINEL-2 data (jp2)  ok?
> ""Driver built-in by default according to
> https://gdal.org/drivers/raster/sentinel2.html#raster-sentinel2
The Sentinel2 driver is indeed built-in, but it requires one of the
JPEG2000 capable drivers to be also available at runtime
You can use for example one of the Docker images at
https://github.com/OSGeo/gdal/tree/master/docker#images-of-releases to
convert a Sentinel2 dataset to something more convenient
Even
http://www.spatialys.com
