[gdal-dev] Issue with resampling algorithm in gdal_array.DatasetReadAsArray python wrapper function
Miguel A. Manso
m.manso at upm.es
Thu Feb 10 08:01:47 PST 2022
Even
Thank you for your comments
I have created a new environment, installed the latest version (3.4.1)
had version 3.0.4 and the problem persisted.
I have done another test which may give the clue as to where the problem
lies. My datasource is an ECW file and if I use this datasource to
extract an area with the gdal_array.DatasetReadAsArray function telling
it to use resample methods other than NearestNeighbour it does not do it
right.
I have cut a slice and stored it as a geotiff, and using this datasource
for the same test has already worked the resample algorithms. It works
with both versions of the libraries.
I'm sorry I can't extract a piece of image to share it as I have no way
to store it in ecw format.
The code used:
ds = gdal.Open("PNOA_MA_OF_ETRS89_HU31_h50_0699.ecw")
x = gdal_array.DatasetReadAsArray( ds, 1, 1, 256, 256, buf_obj=None,
buf_xsize= 384, buf_ysize=384, buf_type=None,
resample_alg=gdal.GRIORA_Lanczos)
src_srs = ogr.osr.SpatialReference()
src_srs.ImportFromEPSG(25830)
wkt_projection = src_srs.ExportToWkt()
driver = gdal.GetDriverByName('GTiff')
dataset = driver.Create( "recorte.tif", 384, 384, 3, gdal.GDT_Byte )
dataset.SetGeoTransform(( x_min, 0.1, 0, y_max, 0, -0.1))
dataset.SetProjection(wkt_projection)
bands = array.shape[0]
for band in range(bands):
dataset.GetRasterBand(band+1).WriteArray( array[ band,:, : ] )
dataset.FlushCache()
bands = None
dataset = None
driver = None
gdalinfo over ECW:
Driver: ECW/ERDAS Compressed Wavelets (SDK 5.3)
Files: PNOA_MA_OF_ETRS89_HU31_h50_0699.ecw
Size is 191800, 124133
Coordinate System is:
PROJCRS["NUTM31",
BASEGEOGCRS["ETRS89",
DATUM["European Terrestrial Reference System 1989",
ELLIPSOID["GRS 1980",6378137,298.257222101,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
ID["EPSG",4258]],
CONVERSION["UTM zone 31N",
METHOD["Transverse Mercator",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",3,
ID["EPSG",8802]],
PARAMETER["Scale factor at natural origin",0.9996,
SCALEUNIT["unity",1],
ID["EPSG",8805]],
PARAMETER["False easting",500000,
LENGTHUNIT["Metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]],
ID["EPSG",16031]],
CS[Cartesian,2],
AXIS["easting",east,
ORDER[1],
LENGTHUNIT["Metre",1]],
AXIS["northing",north,
ORDER[2],
LENGTHUNIT["Metre",1]]]
Data axis to CRS axis mapping: 1,2
Origin = (483820.000000000000000,4390830.000000000000000)
Pixel Size = (0.150000000000000,-0.150000000000000)
Metadata:
COLORSPACE=RGB
COMPRESSION_RATE_TARGET=6
VERSION=2
Corner Coordinates:
Upper Left ( 483820.000, 4390830.000) ( 2d48'40.90"E, 39d40' 1.67"N)
Lower Left ( 483820.000, 4372210.050) ( 2d48'42.54"E, 39d29'57.69"N)
Upper Right ( 512590.000, 4390830.000) ( 3d 8'48.42"E, 39d40' 1.89"N)
Lower Right ( 512590.000, 4372210.050) ( 3d 8'47.15"E, 39d29'57.90"N)
Center ( 498205.000, 4381520.025) ( 2d58'44.75"E, 39d35' 0.22"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Description = Red
Overviews: 95900x62066, 47950x31033, 23975x15516, 11987x7758,
5993x3879, 2996x1939, 1498x969, 749x484, 374x242
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Description = Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Description = Blue
Thank you
Miguel A
El 10/02/2022 a las 14:06, Even Rouault escribió:
> Miguel,
>> I am trying to use the gdal_array.DatasetReadAsArray function to
>> extract a window from a 3B gtif file by indicating the dataset, the
>> upper left corner image coordinates, the window size (256x256) at
>> actual scale in the dataset, the desired buffer size (larger than
>> actual size 341x341) and indicating the resample algorithm.
>> It only works if I select the NearestNeighbour algorithm. In the rest
>> of the cases (Bilinear, bicubic, Lanczos, etc...) what the function
>> returns me is a mosaic that repeats 9 times (3x3) the original image
>> in reduced size.
>> What am I doing wrong or what have I interpreted incorrectly in the API?
> First you should try with the latest release (3.4.1). If you can still
> reproduce the issue, then strip down your code to a minimum standalone
> reproducer script (using only GDAL & numpy) and with a minimum
> reproducing dataset, and provide it here.
> Even
>> Thanks & Best regards
>> Miguel A. Manso
>> MERCATOR Research Group
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
