[gdal-dev] Issue with resampling algorithm in gdal_array.DatasetReadAsArray python wrapper function
    Even Rouault
    even.rouault at spatialys.com
    Thu Feb 10 05:06:40 PST 2022
Miguel,
> I am trying to use the gdal_array.DatasetReadAsArray function to
> extract a window from a 3B gtif file by indicating the dataset, the
> upper left corner image coordinates, the window size (256x256) at
> actual scale in the dataset, the desired buffer size (larger than
> actual size 341x341) and indicating the resample algorithm.
> It only works if I select the NearestNeighbour algorithm. In the rest
> of the cases (Bilinear, bicubic, Lanczos, etc...) what the function
> returns me is a mosaic that repeats 9 times (3x3) the original image
> in reduced size.
> What am I doing wrong or what have I interpreted incorrectly in the API?
First you should try with the latest release (3.4.1). If you can still
reproduce the issue, then strip down your code to a minimum standalone
reproducer script (using only GDAL & numpy) and with a minimum
reproducing dataset, and provide it here.
Even
> Thanks & Best regards
> Miguel A. Manso
> MERCATOR Research Group
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
