[gdal-dev] [External] : Re: how to build netCDF driver plugin
Fengting Chen
fengting.chen at oracle.com
Thu Feb 24 18:10:06 PST 2022
After fix the plugin library name, the netCDF driver plugin on linux is working. However, it still didn’t work on windows:
E:\tmp\gdal>gdalinfo
ERROR 1: Can't load requested DLL: E:\tmp\gdal\bin\gdalplugins\gdal_netCDF.dll
126: The specified module could not be found.
I verified that specified gdal_netCDF.dll exists at above directory and netcdf.dll is in the path of %PATH%.
Any possible problem?
This is a build on gdal 3.4.1.
Thanks,
Sent: Thursday, February 24, 2022 12:54 PM
To: Fengting Chen <fengting.chen at oracle.com>; gdal-dev at lists.osgeo.org
Subject: [External] : Re: [gdal-dev] how to build netCDF driver plugin
- The filename is case sensitive: it must be gdal_netCDF.so/dll since the registration function is called GDALRegister_netCDF()
- You need to set the GDAL_DRIVER_PATH environment variable to point to the directory where the driver is
- You might find it easier when using master to use CMake: cmake -DGDAL_ENABLE_DRIVER_NETCDF_PLUGIN:BOOL=ON . That will work on both Linux and Windows
Le 24/02/2022 à 17:45, Fengting Chen a écrit :
Under current build system, how to build netCDF driver as a plugin on linux and windows?
On windows, when I set NETCDF_PLUGIN=YES, the gdal_netcdf.ddl was built. But gdalinfo still doesn’t show netcdf as a supported format.
On linux, I changed the local makefile for netcdf and built gdal_netcdf.so. But gdalinfo doesn’t show netcdf as a supported format either.
Any help would be appreciated.
Thanks
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!arl8eQzGRDqBZJr6WK8ShQVivQBxsojpL11eSfaFnZOe2MhcbeySDvlb0A2SfGO3X9M$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!arl8eQzGRDqBZJr6WK8ShQVivQBxsojpL11eSfaFnZOe2MhcbeySDvlb0A2SocmiOpw$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220225/8f2e53c1/attachment.html>
