[gdal-dev] [External] : Re: how to build netCDF driver plugin
Mateusz Loskot mateusz at loskot.net
Thu Feb 24 23:39:25 PST 2022
On Fri, 25 Feb 2022, 07:01 Fengting Chen, <fengting.chen at oracle.com> wrote:
> After fix the plugin library name, the netCDF driver plugin on linux is
> working. However, it still didn’t work on windows:
> E:\tmp\gdal>gdalinfo
> ERROR 1: Can't load requested DLL:
> E:\tmp\gdal\bin\gdalplugins\gdal_netCDF.dll
> 126: The specified module could not be found.
> I verified that specified gdal_netCDF.dll exists at above directory and
> netcdf.dll is in the path of %PATH%.
> Any possible problem?
Lots.
Use the process monitor (sysinternals, downloadable from Microsoft website)
to investigate what DLLs are being loaded and from where, and which fail to
be found.
Mateusz Loskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220225/93a6aaac/attachment-0001.html>
