[gdal-dev] Experiences with the WMS driver
Momtchil Momtchev
momtchil at momtchev.com
Tue Jan 4 16:18:01 PST 2022
You can get the raw image with curl (it is just a static image):
$ curl "https://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&request=GetMap&version=1.3.0&layers=3170_21483_bg&styles=&format=image/png&bbox=-180,-90,180,90&crs=CRS:84&transparent=FALSE&width=922&height=461" --output raw.png
Then use gdal_translate to georeference it:
$ gdal_translate -a_srs CRS:84 -a_ullr -180 90 180 -90 raw.png out.png
On 03/01/2022 21:15, Joaquim Manuel Freire Luís wrote:
> Thanks. That’s right that modifying the host name prints the same size
> info but there is nothing in the url that permits to estimate the
> “Pixel Size”.
> Also, this not the main issue. The main one is when passing a valid
> “GetMap” string that works in a browser but errors in gdal_translate.
> *From:*Momtchil Momtchev <momtchil at momtchev.com>
> *Sent:* Monday, January 3, 2022 3:08 PM
> *To:* gdal-dev at lists.osgeo.org; Joaquim Manuel Freire Luís <jluis at ualg.pt>
> *Subject:* Re: [gdal-dev] Experiences with the WMS driver
> gdalinfo does not contact the remote server at all, it extracts
> all the information it displays from the URL.
> Try replacing the hostname with something invalid, keeping all the
> parameters and you will still get the same output.
> On 01/01/2022 19:47, Joaquim Manuel Freire Luís wrote:
> But if I do
> gdalinfo
> "WMS:http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=3170_21483_bg&CRS=CRS:84&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=FALSE
> <http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=3170_21483_bg&CRS=CRS:84&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=FALSE>"
> it seems to work but note the reported sizes and unreasonable
> resolution.
> Data axis to CRS axis mapping: 1,2
> Origin = (-180.000000000000000,90.000000000000000)
> Pixel Size = (0.000000335276127,-0.000000335276127)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
> Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
> Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0'
> 0.00"N)
> Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0'
> 0.00"S)
> Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0'
> 0.01"N)
> Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
> Overviews: 536870912x268435456, 268435456x134217728,
> 134217728x67108864, 67108864x33554432, 33554432x16777216,
> 16777216x8388608, 8388608x4194304, 4194304x2097152,
> 2097152x1048576, 1048576x524288, 524288x262144, 262144x131072,
> 131072x65536, 65536x32768, 32768x16384, 16384x8192, 8192x4096,
> 4096x2048, 2048x1024, 1024x512
> Momtchil Momtchev<momtchil at momtchev.com> <mailto:momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220105/3abcf2c9/attachment.html>
