[gdal-dev] Experiences with the WMS driver
Joaquim Manuel Freire Luís jluis at ualg.pt
Wed Jan 5 07:16:59 PST 2022
Tanks again Momtchil. Your example works indeed ... but not with my layer
curl http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&LAYERS=3140_21200&CRS=CRS:84&FORMAT=image/png&TRANSPARENT=FALSE&HEIGHT=512&BGCOLOR=&REQUEST=GetMap&WIDTH=2048&BBOX=-50.2,69.11,-49.6,69.26&STYLES=&VERSION=1.3.0 --output raw.png
the output is an html file saying
<p>The document has moved <a href=https://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&LAYERS=3140_21200&CRS=CRS:84&FORMAT=image/png&TRANSPARENT=FALSE&HEIGHT=512&BGCOLOR=&REQUEST=GetMap&WIDTH=2048&BBOX=-50.2,69.11,-49.6,69.26&STYLES=&VERSION=1.3.0>here</a>.</p>
</body></html>
Anyway, the curl solution is of little interest for me because I don't know how to programmatically select it instead of using gdal_translate.
Sent: Wednesday, January 5, 2022 12:18 AM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Experiences with the WMS driver
    You can get the raw image with curl (it is just a static image):
$ curl "https://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&request=GetMap&version=1.3.0&layers=3170_21483_bg&styles=&format=image/png&bbox=-180,-90,180,90&crs=CRS:84&transparent=FALSE&width=922&height=461"<https://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&request=GetMap&version=1.3.0&layers=3170_21483_bg&styles=&format=image/png&bbox=-180,-90,180,90&crs=CRS:84&transparent=FALSE&width=922&height=461>  --output raw.png
    Then use gdal_translate to georeference it:
$ gdal_translate -a_srs CRS:84  -a_ullr -180 90 180 -90 raw.png out.png
On 03/01/2022 21:15, Joaquim Manuel Freire Luís wrote:
Thanks. That's right that modifying the host name prints the same size info but there is nothing in the url that permits to estimate the "Pixel Size".
Also, this not the main issue. The main one is when passing a valid "GetMap" string that works in a browser but errors in gdal_translate.
From: Momtchil Momtchev <momtchil at momtchev.com><mailto:momtchil at momtchev.com>
Sent: Monday, January 3, 2022 3:08 PM
To: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>; Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt>
    gdalinfo does not contact the remote server at all, it extracts all the information it displays from the URL.
    Try replacing the hostname with something invalid, keeping all the parameters and you will still get the same output.
On 01/01/2022 19:47, Joaquim Manuel Freire Luís wrote:
But if I do
gdalinfo "WMS:http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=3170_21483_bg&CRS=CRS:84&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=FALSE"
it seems to work but note the reported sizes and unreasonable resolution.
Data axis to CRS axis mapping: 1,2
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000000335276127,-0.000000335276127)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left  (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000,  90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center      (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
  Overviews: 536870912x268435456, 268435456x134217728, 134217728x67108864, 67108864x33554432, 33554432x16777216, 16777216x8388608, 8388608x4194304, 4194304x2097152, 2097152x1048576, 1048576x524288, 524288x262144, 262144x131072, 131072x65536, 65536x32768, 32768x16384, 16384x8192, 8192x4096, 4096x2048, 2048x1024, 1024x512
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220105/79d726d5/attachment-0001.html>
