[gdal-dev] Experiences with the WMS driver
mladen-g at distributel.net mladen-g at distributel.net
Wed Jan 5 08:18:11 PST 2022
Hi Joaquim,
FYI your curl command will work if you update the URL to what is in
the HTML file message (looks like it was moved to HTTPS instead of
HTTP).
I understand it's not what you want in the end, just thought I'd point
it out in case it's useful for troubleshooting.
Quoting jluis at ualg.pt:
> Tanks again Momtchil. Your example works indeed … but not with my layer
> curl
> http://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&LAYERS=3140_21200&CRS=CRS:84&FORMAT=image/png&TRANSPARENT=FALSE&HEIGHT=512&BGCOLOR=&REQUEST=GetMap&WIDTH=2048&BBOX=-50.2,69.11,-49.6,69.26> &STYLES=&VERSION=1.3.0 --output
> the output is an html file saying
> <p>The document has moved <a
> href=https://svs.gsfc.nasa.gov/cgi-bin/wms?SERVICE=WMS&LAYERS=3140_21200&CRS=CRS:84&FORMAT=image/png&TRANSPARENT=FALSE&HEIGHT=512&BGCOLOR=&REQUEST=GetMap&WIDTH=2048&BBOX=-50.2,69.11,-49.6,69.26&STYLES=&VERSION=1.3.0>here</a>.</p>
> </body></html>
> Anyway, the curl solution is of little interest for me because I
> don’t know how to programmatically select it instead of using
> gdal_translate."
