[gdal-dev] Build GDAL for RedHat 7.9 with python bindings and non-default drivers
Roman Breitfuss-Schiffer
roman.schiffer at gmail.com
Tue Jan 11 02:38:55 PST 2022
Dear all!
We are currently trying to build a GDAL/OGR installation (version >=3.1)
for our server which operates on RedHat 7.9 (RHEL).
I have some experience with building GDAL on Ubuntu but have no working
workflow for RHEL as the required packages and header files (e.g.
gdal-libs, gdal-libs-devel, python-devel etc.) are not available for
recent GDAL versions via yum.
*Problem 1: Does anyone have experience with building GDAL **(version
>=3.1)**on RHEL?*
We want to build with Python bindings and some non-default drivers (e.g.
GPKG (raster), JP2OpenJPEG, MBTILES, WMS/WCS). I tried out the build on
Ubuntu with the following ./configure:
./configure
--prefix=/usr
--libdir=/usr/lib64
--with-armadillo=yes
--with-sqlite3=yes
--with-spatialite=yes
--with-openjpeg
--with-geos=yes
--with-curl=/usr/bin/curl-config
--with-python=yes
--with-png=internal
--with-jpeg=internal
*Problem 2: After running the ./configure command the GPKG (raster)
driver and the JP2OpenJPEG driver are not listed in misc. gdal formats.
./configure output see attachment.
Best regards
Roman
Dipl.-Ing. Roman Breitfuss-Schiffer, MSc. (GIS)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220111/b6b682f6/attachment.html>
GDAL is now configured for x86_64-pc-linux-gnu
Installation directory: /usr
C compiler: gcc -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2
C++ compiler: g++ -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2
C++14 support: no
LIBTOOL support: yes
Armadillo support: yes
Blosc support: no
CFITSIO support: external
crypto/openssl support: yes
cryptopp support: no
cURL support (wms/wcs/...):yes
DDS support: no
DODS support: no
ECW support: no
Expat support: yes
EXR support: no
FGDB support: no
FreeXL support: yes
GEORASTER support: no
GEOS support: yes
Google libkml support: yes
GRASS support: no
GTA support: no
HDF4 support: yes
HDF5 support: yes
JXL support: no
HDFS support: no
HEIF support: no
INFORMIX DataBlade support:no
Ingres support: no
JP2Lura support: no
JPEG 12 bit: yes
JPEG-in-TIFF 12 bit: no
JPEG JasPer support: no
JPEG-Lossless/CharLS: yes
Kakadu support: no
Kea support: no
LERC support: internal
libbrunsli support: no
libdeflate support: no
LIBGEOTIFF support: external
LIBGIF support: external
LIBJPEG support: internal
LIBLZMA support: no
LIBPNG support: internal
LIBTIFF support: external (BigTIFF=yes)
libxml2 support: yes
LIBZ support: external
LZ4 support: no
MDB support: no
MongoCXX v3 support: no
MongoDB support: no
MrSID/MG4 Lidar support: no
MrSID support: no
MSG support: no
MySQL support: no
NetCDF has netcdf_mem.h: yes
NetCDF support: yes
OCI support: no
ODBC support: yes
OGDI support: yes
OpenCL support: no
OpenJPEG support: yes
PCIDSK support: internal
PCRaster support: internal
PCRE support: yes
PCRE2 support: no
PDFium support: no
Podofo support: no
Poppler support: no
PostgreSQL support: yes
QHull support: external
Rasdaman support: no
RasterLite2 support: no
RDB support: no
SFCGAL support:
SOSI support: no
SpatiaLite support: yes
SQLite support: yes
Teigha (DWG and DGNv8): no
TileDB support: no
userfaultfd support: yes
WebP support: yes
Xerces-C support: yes
ZSTD support: yes
misc. gdal formats: aaigrid adrg aigrid airsar arg blx bmp bsb cals ceos ceos2 coasp cosar ctg dimap dted elas envisat ers esric fit gff gsg gxf hf2 idrisi ilwis ingr iris iso8211 jaxapalsar jdem kmlsuperoverlay l1b leveller map mrf msgn ngsgeoid nitf northwood pds prf r raw rmf rs2 safe saga sdts sentinel2 sgi sigdem srtmhgt stacit stacta terragen tga til tsx usgsdem xpm xyz zarr zmap rik ozi eeda plmosaic rda wcs wms wmts daas ogcapi rasterlite mbtiles grib pdf
misc. ogr formats: arcgen avc cad csv dgn dxf edigeo flatgeobuf geoconcept georss gml gmt gpsbabel gpx gtm jml mapml mvt ntf openfilegdb pgdump rec s57 selafin shape svg sxf tiger vdv wasp idrisi pds sdts amigocloud carto cloudant couchdb csw elastic ngw plscenes wfs gpkg vfk osm nas ili gmlas ods xlsx lvbag odbc pgeo mssqlspatial geomedia walk
disabled gdal formats:
disabled ogr formats:
SWIG Bindings: python
PROJ >= 6: yes
enable GNM building: yes
enable pthread support: yes
enable POSIX iconv support:yes
hide internal symbols: no
