[gdal-dev] cmake status update - 99% good news!
Kai Pastor, DG0YT
dg0yt at darc.de
Mon Jan 24 23:23:57 PST 2022
I made an initial attempt on gdal with cmake for vcpkg:
https://github.com/microsoft/vcpkg/pull/22392
Now vcpkg's default is static linkage on Linux and macOS. AFAICT static
linkage is not covered very well. Fixing this needs a lot of work either
on the find modules, or on getting dependencies to provide exported
config. In some cases (e.g. GEOS), config files already exist, but they
are neither used nor a drop-in replacement (target names differ).
On the export side, all custom find modules must be made available to
the exported configuration if not burning the depended-on libraries into
the exported cmake config. Generating a complete gdal.pc needs work,
too. CMake doesn't provide any help ATM. (But note
https://gitlab.kitware.com/cmake/cmake/-/issues/22621.)
This is not meant as an argument against shortening the release schedule
for cmake. I just want to underline that the CMake build system will
continue to need significant changes, including user-facing changes.
Kai Pastor
