[gdal-dev] Add elevation data to gpx files
APM apschwimmer at apmland.de
Wed Jan 26 03:14:56 PST 2022
Dear List,
I like to add elevation data to some gpx files by using ogr directly.
The actual files are containing for example:
<trk>
   <name> town </name>
    <trkseg>
     <trkpt lat="xxx" lon= "yyy"/>
etc ....
Before I asked I created a point layer with DEM data in Qgis 3.22.3. by
using the "Point sampling tool" and
imported the gpx.
I use http://www.viewfinderpanoramas.org/ as DEM source and create a
.vrt Raster from it.
Now I have a shape which is containing two attribute fields "fid" and
"dem", which shows correct DEM data according to the gpx-points.
But I can't create an assembled new gpx file which include something like
<trkpt lat="xxx" lon="yyy"/>
<ele>210</ele>
etc...
I would be glad for some help!
Thank you very much!
Kind regards
Piet
