[gdal-dev] cmake status update - 99% good news!
Even Rouault even.rouault at spatialys.com
Wed Jan 26 11:33:57 PST 2022
Le 26/01/2022 à 20:26, Joaquim Manuel Freire Luís a écrit :
> Ok, sorry you meant the FindHDF4.cmake that comes with GDAL. Doing
> what you suggested (tried both) makes no difference but commenting
>     if(WIN32)
>         #list(APPEND HDF4_LIBRARIES ws2_32.lib)
>     endif()
> makes the ws2_32 trouble go.
Ah my if(MSVC) suggestion was because I wrongly assumed you used mingw
(the _w64.dll suffix made me thing of mingw64), but I see the VC14 so
you use MSVC.
Can you try this then ?
if (WIN32)
    find_library(WS2_32_LIBRARY ws2_32)
    if( WS2_32_LIBRARY )
list(APPEND HDF4_LIBRARIES ${WS2_32_LIBRARY})
    endif()
endif()
> Le 26/01/2022 à 20:08, Joaquim Manuel Freire Luís a écrit :
>     Updated master (sorry, didn’t stop to think if the commit had been
>     merged)
>     However, I have cmake 3.22.1 but it doesn’t have a FindHDF4.cmake,
>     only a FinfHDF5
> FindHDF4.cmake is in the GDAL repository, in
> cmake/modules/packages/FindHDF4.cmake, so you can try editing it
> locally with my below suggestions
>     I was building with
>                    set(HDF4_INCLUDE_DIR
>     C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_34/include)
>                    set(HDF4_df_LIBRARY_RELEASE
>     C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/hdfdll.lib)
>                set(HDF4_mfhdf_LIBRARY_RELEASE
>     C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/mfhdfdll.lib)
>     and when I commented those lines the build advance … till it stop
>     at the “Cannot open include file: 'zlib.h'” but that is normal
>     since I’m not using the commit who fixed it.
>     *From:*Even Rouault <even.rouault at spatialys.com>
>     <mailto:even.rouault at spatialys.com>
>     *Sent:* Wednesday, January 26, 2022 6:50 PM
>     *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>
>     <mailto:jluis at ualg.pt>; gdal-dev at lists.osgeo.org
>     *Subject:* Re: [gdal-dev] cmake status update - 99% good news!
>     did you update to master or did you try my pull request (not
>     merged yet) ?
>     If only master, can you try to change the reference to
>     "ws2_32.lib" to "ws2_32" in cmake/modules/packages/FindHDF4.cmake
>     as I suggested ?
>     Or perhaps change the if (WIN32) at line 91 to if (MSVC)
>     Le 26/01/2022 à 19:43, Joaquim Manuel Freire Luís a écrit :
>         Don’t know which commit did it. Updated this afternoon and
>         started to erroring right away with missing 'ws2_32.lib`
>         *Sent:* Wednesday, January 26, 2022 6:36 PM
>         Le 26/01/2022 à 19:31, Joaquim Manuel Freire Luís a écrit :
>             I do have HDF4 but before I was able to build till the
>             end. I've here a gdal_w64.dll smiling to me. That's why I
>             said it got worst.
>         Sorry you lost me. Is https://github.com/OSGeo/gdal/pull/5179
>         <https://github.com/OSGeo/gdal/pull/5179> helping or not ?  If
>         not helping, which commit in it is causing an issue ?
>             Le 26/01/2022 à 17:26, Joaquim Manuel Freire Luís a écrit :
>             > Joaquim,
>             >> But I found two other new issues when adding more
>             dependencies
>             >> 1.
>             C:\programs\compa_libs\gdal_GIT\frmts\mbtiles\mbtilesdataset.cpp(45):
>             >> fatal error C1083: Cannot open include file: 'zlib.h':
>             No such file
>             >> or directory
>             >> To work around this, I temporarily added zlib.h and
>             zconf.h to
>             >> frmts\mbtiles
>             > Should be fixed by the first commit of
>             > I'm afraid it got worst
>             -- Configuring done
>             -- Generating done
>             -- Build files have been written to:
>             C:/programs/compa_libs/gdal_GIT/build
>             ninja: error: 'ws2_32.lib', needed by 'gdal_w64.dll',
>             missing and no known rule to make it
>             I'd say on the contrary that it helped the build to go
>             further, didn't it ? My fixes are totally unrelated to a
>             ws2_32.lib missing
>             I see in configure.ac that we had the following logic
>             dnl
>             dnl Check if we need -lws2_32 (mingw)
>             dnl
>             echo "#include <winsock2.h>" > test_ws2_32.c echo
>             "#include <ws2tcpip.h>" >> test_ws2_32.c echo "void foo()
>             {}" >> test_ws2_32.c
>             if test -z "`${CC} -c test_ws2_32.c 2>&1`" ; then
>               LIBS="$LIBS -lws2_32"
>             fi
>             rm -f test_ws2_32*
>             dnl
>             dnl Check if we need -lpsapi (mingw)
>             dnl
>             echo "#include <windows.h>" > test_psapi.c echo "#include
>             <psapi.h>" >> test_psapi.c echo "void foo() {}" >>
>             test_psapi.c
>             if test -z "`${CC} -c test_psapi.c 2>&1`" ; then
>               LIBS="$LIBS -lpsapi"
>             fi
>             rm -f test_psapi*
>             This hasn't been ported yet to cmake builds.
>             I've ticketed that in
>             https://github.com/OSGeo/gdal/issues/5180
>             <https://github.com/OSGeo/gdal/issues/5180>.
>             Hum, upon reflection, the error message would seem to
>             indicate that we try to link to ws2_32.lib but it is not
>             found in your environemnt
>             Looking for ws2_32 in cmake build scripts, I see it is
>             referenced in
>             cmake/modules/packages/FindODBC.cmake:
>             set(_odbc_required_libs_names
>             odbccp32;ws2_32)
>             cmake/modules/packages/FindHDF4.cmake: list(APPEND
>             HDF4_LIBRARIES
>             ws2_32.lib)
>             Do you use any of ODBC or HDF4 in your build ? Could you
>             try to disable them and see if it makes a difference ?
>             Or maybe if you've HDF4, try to change the ws2_32.lib to
>             ws2_32 in cmake/modules/packages/FindHDF4.cmake ?
>             Even
>             http://www.spatialys.com <http://www.spatialys.com>
>             My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/8a913f35/attachment-0001.html>
