[gdal-dev] cmake status update - 99% good news!
Joaquim Manuel Freire Luís
jluis at ualg.pt
Wed Jan 26 11:41:07 PST 2022
Yes, I’m using MSVC (2022) and yeap, with that change it works fine.
Sent: Wednesday, January 26, 2022 7:34 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] cmake status update - 99% good news!
Le 26/01/2022 à 20:26, Joaquim Manuel Freire Luís a écrit :
Ok, sorry you meant the FindHDF4.cmake that comes with GDAL. Doing what you suggested (tried both) makes no difference but commenting
if(WIN32)
#list(APPEND HDF4_LIBRARIES ws2_32.lib)
endif()
makes the ws2_32 trouble go.
Ah my if(MSVC) suggestion was because I wrongly assumed you used mingw (the _w64.dll suffix made me thing of mingw64), but I see the VC14 so you use MSVC.
Can you try this then ?
if (WIN32)
find_library(WS2_32_LIBRARY ws2_32)
if( WS2_32_LIBRARY )
list(APPEND HDF4_LIBRARIES ${WS2_32_LIBRARY})
endif()
endif()
Le 26/01/2022 à 20:08, Joaquim Manuel Freire Luís a écrit :
Updated master (sorry, didn’t stop to think if the commit had been merged)
However, I have cmake 3.22.1 but it doesn’t have a FindHDF4.cmake, only a FinfHDF5
FindHDF4.cmake is in the GDAL repository, in cmake/modules/packages/FindHDF4.cmake, so you can try editing it locally with my below suggestions
I was building with
set(HDF4_INCLUDE_DIR C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_34/include)
set(HDF4_df_LIBRARY_RELEASE C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/hdfdll.lib)
set(HDF4_mfhdf_LIBRARY_RELEASE C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/mfhdfdll.lib)
and when I commented those lines the build advance … till it stop at the “Cannot open include file: 'zlib.h'” but that is normal since I’m not using the commit who fixed it.
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Sent: Wednesday, January 26, 2022 6:50 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt><mailto:jluis at ualg.pt>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
did you update to master or did you try my pull request (not merged yet) ?
If only master, can you try to change the reference to "ws2_32.lib" to "ws2_32" in cmake/modules/packages/FindHDF4.cmake as I suggested ?
Or perhaps change the if (WIN32) at line 91 to if (MSVC)
Le 26/01/2022 à 19:43, Joaquim Manuel Freire Luís a écrit :
Don’t know which commit did it. Updated this afternoon and started to erroring right away with missing 'ws2_32.lib`
Sent: Wednesday, January 26, 2022 6:36 PM
Le 26/01/2022 à 19:31, Joaquim Manuel Freire Luís a écrit :
I do have HDF4 but before I was able to build till the end. I've here a gdal_w64.dll smiling to me. That's why I said it got worst.
Sorry you lost me. Is https://github.com/OSGeo/gdal/pull/5179 helping or not ? If not helping, which commit in it is causing an issue ?
Le 26/01/2022 à 17:26, Joaquim Manuel Freire Luís a écrit :
> Joaquim,
>> But I found two other new issues when adding more dependencies
>> 1.
>> C:\programs\compa_libs\gdal_GIT\frmts\mbtiles\mbtilesdataset.cpp(45):
>> fatal error C1083: Cannot open include file: 'zlib.h': No such file
>> or directory
>> To work around this, I temporarily added zlib.h and zconf.h to
>> frmts\mbtiles
> Should be fixed by the first commit of
> I'm afraid it got worst
-- Configuring done
-- Generating done
-- Build files have been written to: C:/programs/compa_libs/gdal_GIT/build
ninja: error: 'ws2_32.lib', needed by 'gdal_w64.dll', missing and no known rule to make it
I'd say on the contrary that it helped the build to go further, didn't it ? My fixes are totally unrelated to a ws2_32.lib missing
I see in configure.ac that we had the following logic
dnl
dnl Check if we need -lws2_32 (mingw)
dnl
echo "#include <winsock2.h>" > test_ws2_32.c echo "#include <ws2tcpip.h>" >> test_ws2_32.c echo "void foo() {}" >> test_ws2_32.c
if test -z "`${CC} -c test_ws2_32.c 2>&1`" ; then
LIBS="$LIBS -lws2_32"
fi
rm -f test_ws2_32*
dnl
dnl Check if we need -lpsapi (mingw)
dnl
echo "#include <windows.h>" > test_psapi.c echo "#include <psapi.h>" >> test_psapi.c echo "void foo() {}" >> test_psapi.c
if test -z "`${CC} -c test_psapi.c 2>&1`" ; then
LIBS="$LIBS -lpsapi"
fi
rm -f test_psapi*
This hasn't been ported yet to cmake builds.
I've ticketed that in https://github.com/OSGeo/gdal/issues/5180.
Hum, upon reflection, the error message would seem to indicate that we try to link to ws2_32.lib but it is not found in your environemnt
Looking for ws2_32 in cmake build scripts, I see it is referenced in
cmake/modules/packages/FindODBC.cmake: set(_odbc_required_libs_names
odbccp32;ws2_32)
cmake/modules/packages/FindHDF4.cmake: list(APPEND HDF4_LIBRARIES
ws2_32.lib)
Do you use any of ODBC or HDF4 in your build ? Could you try to disable them and see if it makes a difference ?
Or maybe if you've HDF4, try to change the ws2_32.lib to ws2_32 in cmake/modules/packages/FindHDF4.cmake ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/2f01817c/attachment-0001.html>
