[gdal-dev] cmake status update - 99% good news!
Even Rouault
even.rouault at spatialys.com
Wed Jan 26 11:46:26 PST 2022
Le 26/01/2022 à 20:41, Joaquim Manuel Freire Luís a écrit :
> Yes, I’m using MSVC (2022) and yeap, with that change it works fine.
great. Queued in https://github.com/OSGeo/gdal/pull/5179
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, January 26, 2022 7:34 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] cmake status update - 99% good news!
> Le 26/01/2022 à 20:26, Joaquim Manuel Freire Luís a écrit :
> Ok, sorry you meant the FindHDF4.cmake that comes with GDAL. Doing
> what you suggested (tried both) makes no difference but commenting
> if(WIN32)
> #list(APPEND HDF4_LIBRARIES ws2_32.lib)
> endif()
> makes the ws2_32 trouble go.
> Ah my if(MSVC) suggestion was because I wrongly assumed you used mingw
> (the _w64.dll suffix made me thing of mingw64), but I see the VC14 so
> you use MSVC.
> Can you try this then ?
> if (WIN32)
> find_library(WS2_32_LIBRARY ws2_32)
> if( WS2_32_LIBRARY )
> list(APPEND HDF4_LIBRARIES ${WS2_32_LIBRARY})
> endif()
> endif()
> Le 26/01/2022 à 20:08, Joaquim Manuel Freire Luís a écrit :
> Updated master (sorry, didn’t stop to think if the commit had
> been merged)
> However, I have cmake 3.22.1 but it doesn’t have a
> FindHDF4.cmake, only a FinfHDF5
> FindHDF4.cmake is in the GDAL repository, in
> cmake/modules/packages/FindHDF4.cmake, so you can try editing it
> locally with my below suggestions
> I was building with
> set(HDF4_INCLUDE_DIR
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_34/include)
> set(HDF4_df_LIBRARY_RELEASE
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/hdfdll.lib)
> set(HDF4_mfhdf_LIBRARY_RELEASE
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/mfhdfdll.lib)
> and when I commented those lines the build advance … till it
> stop at the “Cannot open include file: 'zlib.h'” but that is
> normal since I’m not using the commit who fixed it.
> <mailto:even.rouault at spatialys.com>
> *Sent:* Wednesday, January 26, 2022 6:50 PM
> <mailto:jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> did you update to master or did you try my pull request (not
> merged yet) ?
> If only master, can you try to change the reference to
> "ws2_32.lib" to "ws2_32" in
> cmake/modules/packages/FindHDF4.cmake as I suggested ?
> Or perhaps change the if (WIN32) at line 91 to if (MSVC)
> Le 26/01/2022 à 19:43, Joaquim Manuel Freire Luís a écrit :
> Don’t know which commit did it. Updated this afternoon and
> started to erroring right away with missing 'ws2_32.lib`
> *Sent:* Wednesday, January 26, 2022 6:36 PM
> Le 26/01/2022 à 19:31, Joaquim Manuel Freire Luís a écrit :
> I do have HDF4 but before I was able to build till the
> end. I've here a gdal_w64.dll smiling to me. That's
> why I said it got worst.
> Sorry you lost me. Is
> <https://github.com/OSGeo/gdal/pull/5179> helping or not
> ? If not helping, which commit in it is causing an issue ?
> Le 26/01/2022 à 17:26, Joaquim Manuel Freire Luís a
> écrit :
> > Joaquim,
> >> But I found two other new issues when adding more
> dependencies
> >> 1.
> C:\programs\compa_libs\gdal_GIT\frmts\mbtiles\mbtilesdataset.cpp(45):
> >> fatal error C1083: Cannot open include file:
> 'zlib.h': No such file
> >> or directory
> >> To work around this, I temporarily added zlib.h and
> zconf.h to
> >> frmts\mbtiles
> > Should be fixed by the first commit of
> > I'm afraid it got worst
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> C:/programs/compa_libs/gdal_GIT/build
> ninja: error: 'ws2_32.lib', needed by 'gdal_w64.dll',
> missing and no known rule to make it
> I'd say on the contrary that it helped the build to go
> further, didn't it ? My fixes are totally unrelated to
> a ws2_32.lib missing
> I see in configure.ac that we had the following logic
> dnl
> dnl Check if we need -lws2_32 (mingw)
> dnl
> echo "#include <winsock2.h>" > test_ws2_32.c echo
> "#include <ws2tcpip.h>" >> test_ws2_32.c echo "void
> foo() {}" >> test_ws2_32.c
> if test -z "`${CC} -c test_ws2_32.c 2>&1`" ; then
> LIBS="$LIBS -lws2_32"
> fi
> rm -f test_ws2_32*
> dnl
> dnl Check if we need -lpsapi (mingw)
> dnl
> echo "#include <windows.h>" > test_psapi.c echo
> "#include <psapi.h>" >> test_psapi.c echo "void foo()
> {}" >> test_psapi.c
> if test -z "`${CC} -c test_psapi.c 2>&1`" ; then
> LIBS="$LIBS -lpsapi"
> fi
> rm -f test_psapi*
> This hasn't been ported yet to cmake builds.
> I've ticketed that in
> https://github.com/OSGeo/gdal/issues/5180
> <https://github.com/OSGeo/gdal/issues/5180>.
> Hum, upon reflection, the error message would seem to
> indicate that we try to link to ws2_32.lib but it is
> not found in your environemnt
> Looking for ws2_32 in cmake build scripts, I see it is
> referenced in
> cmake/modules/packages/FindODBC.cmake:
> set(_odbc_required_libs_names
> odbccp32;ws2_32)
> cmake/modules/packages/FindHDF4.cmake: list(APPEND
> HDF4_LIBRARIES
> ws2_32.lib)
> Do you use any of ODBC or HDF4 in your build ? Could
> you try to disable them and see if it makes a difference ?
> Or maybe if you've HDF4, try to change the ws2_32.lib
> to ws2_32 in cmake/modules/packages/FindHDF4.cmake ?
> Even
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/657c0bd2/attachment-0001.html>
