[gdal-dev] Creating a vector mbtile with several layers
DELEPINE Christophe christophe.delepine at thalesgroup.com
Fri Jul 1 04:59:49 PDT 2022
Hi Even
I managed to get it working. There was a bug in my code which prevented features to be added to the second layer. In that case, the driver does not export the empty layer.
In the MVT driver documentation, it says : Part of the conversion is multi-threaded by default, using as many threads as there are cores. The number of threads used can be controlled with the GDAL_NUM_THREADS configuration option.
Do you know if that is also the case for the MBTILES driver ?
Regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220701/50e19bfa/attachment.htm>
