[gdal-dev] Creating a vector mbtile with several layers
Even Rouault even.rouault at spatialys.com
Fri Jul 1 05:53:25 PDT 2022
Le 01/07/2022 à 13:59, DELEPINE Christophe a écrit :
> Hi Even
> I managed to get it working. There was a bug in my code which
> prevented features to be added to the second layer. In that case, the
> driver does not export the empty layer.
> In the MVT driver documentation, it says : Part of the conversion is
> multi-threaded by default, using as many threads as there are cores.
> The number of threads used can be controlled with the
> GDAL_NUM_THREADS configuration option.
> Do you know if that is also the case for the MBTILES driver ?
yes, most of the code for vector MBTiles and MVT creation is common.
Just added in the doc
> Regards
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220701/7ca38bfa/attachment.htm>
