[gdal-dev] Multiproc stub by default
DELEPINE Christophe christophe.delepine at thalesgroup.com
Mon Jul 4 02:57:38 PDT 2022
Hi Even
I have looked at cpl_multiproc.cpp implementation and I believe that I cannot use multithreading for the mbtiles conversion (even if I define GDAL_NUM_THREADS)
The compilation of cpl_multiproc.cpp depends on several compilation flags :
·        CPL_MULTIPROC_STUB
·        CPL_MULTIPROC_WIN32
·        CPL_MULTIPROC_PTHREAD
·        CPL_MULTIPROC_NONE
If none of them is defined, then CPL_MULTIPROC_STUB is defined automatically which means that multithreading is disabled (thread creation does not work).
I am using windows binaries of gdal I get from this site : GISInternals Support Site<https://www.gisinternals.com/release.php>
It seems that none of these symbols have been defined for this build process
I guess I would have to recompile gdal in order to enable multithreading…
Regards
Christophe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220704/7a9ed52b/attachment-0001.htm>
