[gdal-dev] Multiproc stub by default
Even Rouault
even.rouault at spatialys.com
Mon Jul 4 03:08:02 PDT 2022
Christophe,
CPL_MULTIPROC_WIN32 is automatically set on Windows by
https://github.com/OSGeo/gdal/blob/104e1747748d204e8aff1945464a24b1f8c94c90/port/cpl_multiproc.h#L43
Even
Le 04/07/2022 à 11:57, DELEPINE Christophe a écrit :
> Hi Even
> I have looked at cpl_multiproc.cpp implementation and I believe that I
> cannot use multithreading for the mbtiles conversion (even if I define
> GDAL_NUM_THREADS)
> The compilation of cpl_multiproc.cpp depends on several compilation
> flags :
> ·CPL_MULTIPROC_STUB
> ·CPL_MULTIPROC_WIN32
> ·CPL_MULTIPROC_PTHREAD
> ·CPL_MULTIPROC_NONE
> If none of them is defined, then CPL_MULTIPROC_STUB is defined
> automatically which means that multithreading is disabled (thread
> creation does not work).
> I am using windows binaries of gdal I get from this site :
> GISInternals Support Site <https://www.gisinternals.com/release.php>
> It seems that none of these symbols have been defined for this build
> process
> I guess I would have to recompile gdal in order to enable multithreading…
> Regards
> Christophe
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220704/a15156e5/attachment.htm>
