[gdal-dev] Build GDAL 3.5 for iOS error: forward declaration of 'stat64'
Greg Troxel
gdt at lexort.com
Tue Jul 5 05:34:10 PDT 2022
Even Rouault <even.rouault at spatialys.com> writes:
> Can you try the following patch which basically forces to remap all
> "foo64" functions to "foo". I assume that iOS Unix I/O is 64-bit
> enabled by default...
I would expect it is. The BSD world changed the ttype of size_t, off_t
to 64 bits a really long time ago and in the particular case of NetBSD
versioned the syscalls for binary compat (probably others did too). I
have viewed "large file support" as a linux and solaris thing only.
This is probably a bigger rototill than anyone has appetite for, but I
wonder if there should basically be a configure test to look for foo64
(by the equivalent of AC_TRY_COMPILE) and if so use it,a nd if not just
use the normal system calls.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220705/40e2afdb/attachment.sig>
