[gdal-dev] GDAL 3.5 successfully built for iOS with cmake
Even Rouault even.rouault at spatialys.com
Wed Jul 6 01:28:36 PDT 2022
Nik,
can you revert your patches and just try the one at
https://github.com/OSGeo/gdal/pull/6024 ?
The difference with my previous one is that it also unset variables in
the cache. Testing locally on Linux (by running it unconditionnaly), I
now see that the generated port/cpl_config.h in the build directory no
longer define HAVE_STATVFS64, which should avoid the need for your patch
in the .cpp file
Even
Le 06/07/2022 à 08:41, Nik Sands a écrit :
> Hello again,
> This is just a quick note to follow up on my many questions over the past few days.
> I have successfully built GDAL 3.5 for iOS, and I have fully documented the procedure I used at:
> 	https://gis.stackexchange.com/questions/434514/build-gdal-3-x-for-ios/435316#435316
> Note that it includes two patches.  The second patch is a very dodgy kludge.  I hope that people who know better than I do will be able to come up with a better solution and that both patches will be incorporated into future distributions of GDAL.
> Thanks to Even and the many other people who replied and offered advice and suggestions (and a patch).
> Cheers,
> Nik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
