[gdal-dev] GDAL 3.5 successfully built for iOS with cmake
Paul Harwood
runette at gmail.com
Wed Jul 6 02:44:18 PDT 2022
What would be very nice would be if you created a PR to add the iOS build
hints to gdal.org - so that this knowledge does not get lost ...
On Wed, 6 Jul 2022 at 10:21, Nik Sands <nik at nixanz.com> wrote:
> Hi Even,
> Yes, you’re updated patch has worked on a (clean) distribution of version
> 3.5. It has built for iOS successfully now, without my second dodgy
> work-around patch.
> Thanks again.
> Nik.
> On 6 Jul 2022, at 6:28 pm, Even Rouault <even.rouault at spatialys.com>
> wrote:
> Nik,
> can you revert your patches and just try the one at
> https://github.com/OSGeo/gdal/pull/6024 ?
> The difference with my previous one is that it also unset variables in the
> cache. Testing locally on Linux (by running it unconditionnaly), I now see
> that the generated port/cpl_config.h in the build directory no longer
> define HAVE_STATVFS64, which should avoid the need for your patch in the
> .cpp file
> Even
> Le 06/07/2022 à 08:41, Nik Sands a écrit :
> Hello again,
> This is just a quick note to follow up on my many questions over the past
> few days.
> I have successfully built GDAL 3.5 for iOS, and I have fully documented
> the procedure I used at:
> https://gis.stackexchange.com/questions/434514/build-gdal-3-x-for-ios/435316#435316
> Note that it includes two patches. The second patch is a very dodgy
> kludge. I hope that people who know better than I do will be able to come
> up with a better solution and that both patches will be incorporated into
> future distributions of GDAL.
> Thanks to Even and the many other people who replied and offered advice
> and suggestions (and a patch).
> Cheers,
> Nik.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> NIK SANDS
> Line Tamer | Time Traveller | Space Cadet
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220706/052a48c1/attachment-0001.htm>
