[gdal-dev] Authentication bearer token for WFS driver
Francesco Bartoli xbartolone at gmail.com
Fri Jul 8 14:12:46 PDT 2022
Hi devs,
is that authentication mechanism supported to consume a GeoServer layer protected by an OpenID Connect provider? I’m trying to implement a pygeoapi collection protected by the same OIDC provider via the OGR plugin but I need to figure out how the GDAL command line request would look like to pass the bearer token through.
Do you have an example for the authentication scheme once the HttpAuth has been set to ANY (ref. https://gdal.org/drivers/vector/wfs.html#dataset-name-syntax)?
Thank you in advance for your help.
Francesco
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220708/ce10415c/attachment.htm>
