[gdal-dev] Authentication bearer token for WFS driver
Even Rouault
even.rouault at spatialys.com
Fri Jul 8 14:19:39 PDT 2022
Francesco,
You should rather set the GDAL_HTTP_HEADER_FILE configuration option /
environment variable to the filename of a text file which contains a
line like
Authorization: Bearer XXXX
Even
Le 08/07/2022 à 23:12, Francesco Bartoli a écrit :
> Hi devs,
> is that authentication mechanism supported to consume a GeoServer
> layer protected by an OpenID Connect provider? I’m trying to implement
> a pygeoapi collection protected by the same OIDC provider via the OGR
> plugin but I need to figure out how the GDAL command line request
> would look like to pass the bearer token through.
> Do you have an example for the authentication scheme once the
> *HttpAuth* has been set to *ANY* (ref.
> https://gdal.org/drivers/vector/wfs.html#dataset-name-syntax)?
> Thank you in advance for your help.
> Francesco
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220708/f7885e6d/attachment.htm>
