[gdal-dev] Ogr2ogr issue with big integers
Moises Calzado mcalzado at carto.com
Mon Jul 18 06:54:20 PDT 2022
 test.csv
<https://drive.google.com/file/d/11moLc5Shd78iTCKzsHxCKL33xSFHaVva/view?usp=drive_web>
Hello everyone!
I'm dealing with some issues with ogr2ogr trying to convert my data to a
CSV file guessing the data types. I'm using the following command:
ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/ CSV:test.csv -oo
AUTODETECT_TYPE=YES -lco CREATE_CSVT=YES > test.csv
When I add the AUTODETECT_TYPE=YES flag, ogr2ogr is applying some weird
transformations on the "uprn" column. If you check the generated output and
the original file, you'll notice that some integers have changed into a
negative number. Do you know if I'm doing something wrong, or if it's a
bug?
Thanks so much for your help,
Regards!
*Moises Calzado*
Support Engineer
(US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
<https://www.carto.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220718/84bfee09/attachment.htm>
