[gdal-dev] Ogr2ogr conversion to geojson problem..... any suggestion?
Even Rouault even.rouault at spatialys.com
Sat Jun 11 03:20:39 PDT 2022
Frando Alexis,
when using ogr2ogr, there are 3 components involved:
- the driver that reads the input file
- the driver that writes the output file
- the ogr2ogr specific logic
So when analyzing an issue, it is important to try to localize where it is.
Here the issue comes from the input driver, as you can easily see when
running "ogrinfo your.xtf" (I had to slightly edit the one you pasted
since it was invalid XML)
$ ogrinfo test.xtf -al
INFO: Open of `test.xtf'
       using driver `Interlis 2' successful.
Layer name: testModel.table
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
TID: String (0.0)
OGRFeature(testModel.table):1
   TID (String) = 234921
   name (String) = angela
So the issue lies in the Interlis 2 driver. I've not dug further to know
if the Interlis 2 format is supposed to deal with repeated XML element
names.
Even
Le 11/06/2022 à 04:11, Gonzalez Velasquez, Frando Alexis a écrit :
> Hi dev team!
> I am writing to inquire about conversion to geojson problem, I will
> show you in a little and simple example that shows my big problem:
> We are using the ogr2ogr executables commands like this :
> */ogr2ogr -f GeoJSON C:\tmp\nombres.json C:\tmp\TUNJA1R_ejemplo.xtf
> testModel.table/*
> As you can see, The input file is “TUNJA1R_ejemplo.xtf” a simple array
> of names in xml example, but with the same name of key :
> “<?xml version="1.0" encoding="UTF-8"?><TRANSFER
> xmlns=http://www.interlis.ch/INTERLIS2.3>
> <HEADERSECTION
> SENDER="ili2ora-4.4.3-658b7daf37ba45ed2330ca3e3a3c3d59c96e91fa"
> VERSION="2.3"><MODELS>
> <MODEL NAME="testModel" VERSION="2022-06-10" URI=mailto:PC4 at localhost
> <mailto:PC4 at localhost>></MODEL></MODELS></HEADERSECTION>
> <DATASECTION>
> <testModel BID="testModel">
> <testModel.table TID="234921">
> <name>pepe</name>
> < name >maria</ name >
> < name >juana</name >
> <nestedfield>
> < name >julia</ name > //also try a nested field, wioth results….
> </nestedfield>
> < name >mario</ name >
> < name >luz</ name >
> < name >*angela*</ name >
>                 </testModel.table>
> </Submodelo_Insumos_SNR_V1_0.Datos_SNR>
> </DATASECTION>
> </TRANSFER>”
> After execution, the output file  “ nombres.json ”of conversion always
> leaves only the last key value :
> "type": "FeatureCollection",
> "name": "testModel.table",
> "features": [
> { "type": "Feature", "properties": { "TID": "234921", " name ":
> "*angela*" }, "geometry": null }
> *Is there any strategy to handle this problem like an extra command or
> option (-option) on the command line to get in the output file with
> all the names even the input file has the same key name ?*because, i
> saw that ogr2ogr always update the same key with the last value, and
> we need */all the seven names/* array in the output json file on the
> same registry.
> Finally, I have come to think that I should modify the ogr2ogr code to
> better handle this and not always leave the last value in the
> conversion, but I hope it is the last option that I should take.
> Any advice would be really appreciated, thanks!!!
> minsait-indra
> FRANDO GONZÁLEZ
> Senior Systems Engineer
> fagonzalezv at indracompany.com <mailto:fagonzalezv at indracompany.com>
> Calle 93 16 25
> Bogotá, Colombia
> T +57 1 646 36 00
> M +57 3006604908
> minsait.com
> <https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.minsait.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0Jr%2BkI3f3Uh3g%2FG5C5yElQX9pHauhEi9ds6w%2FPOxLtM%3D&reserved=0>
> indracompany.com
> <https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.indracompany.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=W2xsw4RMlZ8TUymKMTE5zqosvKN2LV5QhwvGmAxgZM0%3D&reserved=0>
> Este correo electrónico y, en su caso, cualquier fichero anexo al
> mismo, contiene información de carácter confidencial exclusivamente
> dirigida a su destinatario o destinatarios. Si no es vd. el
> destinatario indicado, queda notificado que la lectura, utilización,
> divulgación y/o copia sin autorización está prohibida en virtud de la
> legislación vigente. En el caso de haber recibido este correo
> electrónico por error, se ruega notificar inmediatamente esta
> circunstancia mediante reenvío a la dirección electrónica del remitente.
> Evite imprimir este mensaje si no es estrictamente necesario.
> This email and any file attached to it (when applicable) contain(s)
> confidential information that is exclusively addressed to its
> recipient(s). If you are not the indicated recipient, you are informed
> that reading, using, disseminating and/or copying it without
> authorisation is forbidden in accordance with the legislation in
> effect. If you have received this email by mistake, please immediately
> notify the sender of the situation by resending it to their email address.
> Avoid printing this message if it is not absolutely necessary.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220611/37daeeb0/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220611/37daeeb0/attachment.png>
