[gdal-dev] Possibility to use config options in VRT-files
Pekka Sarkola
pekka at gispo.fi
Tue Jun 14 06:19:34 PDT 2022
Ok, I understand and agree with this security issue.
However, I still have problems with the WFS service file.
This works perfectly:
ogrinfo WFS:
https://geodata.tampere.fi/geoserver/wfs?typename=maankaytto:KAAVAYKSIKOT_ALUE_MVIEW
-al -so --config OGR_WFS_PAGING_ALLOWED OFF
Without OGR_WFS_PAGING_ALLOWED, I got some HTTP 400 errors.
I create WFS Service file (tre_wfs.xml):
<OGRWFSDataSource>
<URL>
</URL>
<PagingAllowed>OFF</PagingAllowed>
</OGRWFSDataSource>
When I run this service file with ogrinfo:
ogrinfo -ro tre_wfs.xml -al -so
I also got those HTTP 400 errors. However, if I add config parameter:
ogrinfo -ro tre_wfs.xml -al -so --config OGR_WFS_PAGING_ALLOWED OFF
It works, I'm confused.
Rgs,
Pekka
ti 14. kesäk. 2022 klo 15.52 Even Rouault (even.rouault at spatialys.com)
kirjoitti:
> Hi,
> It is not possible to set configuration options in VRT files. There could
> potentially be security issues in doing so and reading untrusted VRT.
> Even
> Le 14/06/2022 à 14:49, Pekka Sarkola a écrit :
> Hi!
> I had some other problems with the WFS service description file, need to
> check that.
> However, in another case I'd like to use GML_ATTRIBUTES_TO_OGR_FIELDS
> -config for WFS service.
> Rgs,
> Pekka
> ti 14. kesäk. 2022 klo 8.58 Rahkonen Jukka (
> jukka.rahkonen at maanmittauslaitos.fi) kirjoitti:
>> Hi,
>> Do you need to use just the OGR virtual format
>> https://gdal.org/drivers/vector/vrt.html? The simple WFS service
>> description file https://gdal.org/drivers/vector/wfs.html seems to
>> support an additional PagingAllowed element as immediate children of the
>> OGRWFSDataSource for that purpose.
>> -Jukka Rahkonen-
>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Pekka
>> Sarkola
>> *Lähetetty:* tiistai 14. kesäkuuta 2022 8.34
>> *Vastaanottaja:* 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <
>> gdal-dev at lists.osgeo.org>
>> *Aihe:* [gdal-dev] Possibility to use config options in VRT-files
>> Hi!
>> Could it be possible to add GDAL configuration options to VRT-files?
>> I have worked with several WFS-services, where I have to set
>> OGR_WFS_PAGING_ALLOWED=OFF -option to get data.It is not problem to add
>> system variable or --config when running ogrinfo/ogr2ogr from command line.
>> But I like to use the same .vrt-files also in QGIS and it will be more
>> convenient to add necessary config-options to vrt-files.
>> Rgs,
>> Pekka
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220614/b966c393/attachment.htm>
