[gdal-dev] Possibility to use config options in VRT-files
Even Rouault
even.rouault at spatialys.com
Tue Jun 14 05:52:22 PDT 2022
It is not possible to set configuration options in VRT files. There
could potentially be security issues in doing so and reading untrusted VRT.
Even
Le 14/06/2022 à 14:49, Pekka Sarkola a écrit :
> Hi!
> I had some other problems with the WFS service description file, need
> to check that.
> However, in another case I'd like to use GML_ATTRIBUTES_TO_OGR_FIELDS
> -config for WFS service.
> Rgs,
> Pekka
> ti 14. kesäk. 2022 klo 8.58 Rahkonen Jukka
> (jukka.rahkonen at maanmittauslaitos.fi) kirjoitti:
> Hi,
> Do you need to use just the OGR virtual format
> https://gdal.org/drivers/vector/vrt.html? The simple WFS service
> description file https://gdal.org/drivers/vector/wfs.html seems to
> support an additional PagingAllowed element as immediate children
> of the OGRWFSDataSource for that purpose.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Pekka Sarkola
> *Lähetetty:* tiistai 14. kesäkuuta 2022 8.34
> *Vastaanottaja:* 'gdal-dev at lists.osgeo.org'
> (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
> *Aihe:* [gdal-dev] Possibility to use config options in VRT-files
> Hi!
> Could it be possible to add GDAL configuration options to VRT-files?
> I have worked with several WFS-services, where I have to set
> OGR_WFS_PAGING_ALLOWED=OFF -option to get data.It is not problem
> to add system variable or --config when running ogrinfo/ogr2ogr
> from command line. But I like to use the same .vrt-files also in
> QGIS and it will be more convenient to add necessary
> config-options to vrt-files.
> Rgs,
> Pekka
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220614/d835b584/attachment.htm>
