[gdal-dev] Possibility to use config options in VRT-files
Pekka Sarkola
pekka at gispo.fi
Tue Jun 14 05:49:15 PDT 2022
Hi!
I had some other problems with the WFS service description file, need to
check that.
However, in another case I'd like to use GML_ATTRIBUTES_TO_OGR_FIELDS
-config for WFS service.
Rgs,
Pekka
ti 14. kesäk. 2022 klo 8.58 Rahkonen Jukka (
jukka.rahkonen at maanmittauslaitos.fi) kirjoitti:
> Hi,
> Do you need to use just the OGR virtual format
> https://gdal.org/drivers/vector/vrt.html? The simple WFS service
> description file https://gdal.org/drivers/vector/wfs.html seems to
> support an additional PagingAllowed element as immediate children of the
> OGRWFSDataSource for that purpose.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Pekka
> Sarkola
> *Lähetetty:* tiistai 14. kesäkuuta 2022 8.34
> *Vastaanottaja:* 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <
> gdal-dev at lists.osgeo.org>
> *Aihe:* [gdal-dev] Possibility to use config options in VRT-files
> Hi!
> Could it be possible to add GDAL configuration options to VRT-files?
> I have worked with several WFS-services, where I have to set
> OGR_WFS_PAGING_ALLOWED=OFF -option to get data.It is not problem to add
> system variable or --config when running ogrinfo/ogr2ogr from command line.
> But I like to use the same .vrt-files also in QGIS and it will be more
> convenient to add necessary config-options to vrt-files.
> Rgs,
> Pekka
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220614/99e37fc5/attachment-0001.htm>
