[gdal-dev] Possibility to use config options in VRT-files
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 13 22:58:20 PDT 2022
Do you need to use just the OGR virtual format https://gdal.org/drivers/vector/vrt.html? The simple WFS service description file https://gdal.org/drivers/vector/wfs.html seems to support an additional PagingAllowed element as immediate children of the OGRWFSDataSource for that purpose.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Pekka Sarkola
Lähetetty: tiistai 14. kesäkuuta 2022 8.34
Vastaanottaja: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Possibility to use config options in VRT-files
Hi!
Could it be possible to add GDAL configuration options to VRT-files?
I have worked with several WFS-services, where I have to set OGR_WFS_PAGING_ALLOWED=OFF -option to get data.It is not problem to add system variable or --config when running ogrinfo/ogr2ogr from command line. But I like to use the same .vrt-files also in QGIS and it will be more convenient to add necessary config-options to vrt-files.
Rgs,
Pekka
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220614/ba921eb9/attachment.htm>
