[gdal-dev] python - convert CSV of point coordinates to geopackage
Alan Snow
alansnow21 at gmail.com
Thu Jun 16 17:48:07 PDT 2022
These references may be helpful:
https://geopandas.org/en/stable/docs/user_guide/io.html
https://geopandas.org/en/stable/docs/reference/api/geopandas.points_from_xy.html
On Thu, Jun 16, 2022, 7:14 PM Emily Soth <esoth at stanford.edu> wrote:
> Hi,
> I am trying to create a geopackage from a CSV of point coordinates making
> use of the X_POSSIBLE_NAMES and Y_POSSIBLE_NAMES open options on the CSV
> driver.
> I have tried a few things (details are in a gist
> <https://gist.github.com/emlys/60db94cb4017a78219a1aa1dadc0914d>). To
> summarize, I can only set the open options when opening as a gdal.Dataset,
> but then I cannot copy that back into a vector format.
> In the source code it looks like open options can be passed to the CSV
> driver's Open function (source
> <https://github.com/OSGeo/gdal/blob/35c07b18316b4b6d238f6d60b82c31e25662ad27/ogr/ogrsf_frmts/csv/ogrcsvdriver.cpp#L142-L167>)
> but I don't know how to use this from the python API since the python
> ogr.Driver.Open function doesn't accept open options unlike gdal.OpenEx.
> Thank you!
> - Emily
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220616/e6d13953/attachment.htm>
