[gdal-dev] python - convert CSV of point coordinates to geopackage
Thomas Gratier osgeo.mailinglist at gmail.com
Fri Jun 17 17:36:18 PDT 2022
One possible approach using only GDAL
https://gist.github.com/ThomasG77/1c76c8fd4f6ee08d9da88dfdb911cfcb
It can be also made with higher level abstraction package like geopandas or
fiona like mentioned by Alan (also in the same link)
Regards
Thomas Gratier
PS: not sure I've code the fastest solution for 3 approaches
Le ven. 17 juin 2022 à 02:48, Alan Snow <alansnow21 at gmail.com> a écrit :
> These references may be helpful:
> https://geopandas.org/en/stable/docs/user_guide/io.html
> https://geopandas.org/en/stable/docs/reference/api/geopandas.points_from_xy.html
> On Thu, Jun 16, 2022, 7:14 PM Emily Soth <esoth at stanford.edu> wrote:
>> Hi,
>> I am trying to create a geopackage from a CSV of point coordinates making
>> use of the X_POSSIBLE_NAMES and Y_POSSIBLE_NAMES open options on the CSV
>> driver.
>> I have tried a few things (details are in a gist
>> <https://gist.github.com/emlys/60db94cb4017a78219a1aa1dadc0914d>). To
>> summarize, I can only set the open options when opening as a gdal.Dataset,
>> but then I cannot copy that back into a vector format.
>> In the source code it looks like open options can be passed to the CSV
>> driver's Open function (source
>> <https://github.com/OSGeo/gdal/blob/35c07b18316b4b6d238f6d60b82c31e25662ad27/ogr/ogrsf_frmts/csv/ogrcsvdriver.cpp#L142-L167>)
>> but I don't know how to use this from the python API since the python
>> ogr.Driver.Open function doesn't accept open options unlike gdal.OpenEx.
>> Thank you!
>> - Emily
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220618/dd287caa/attachment.htm>
