[gdal-dev] convert to ESRI Shapefile- datetime as a string?
Even Rouault even.rouault at spatialys.com
Fri Jun 17 08:29:07 PDT 2022
Ashley,
try adding "-mapFieldType DateTime=String". See
https://gdal.org/programs/ogr2ogr.html#cmdoption-ogr2ogr-mapFieldType
You won't get a ISO datetime but the historical format used by OGR:
"YYYY/MM/DD HH:MM:SS"
Even
Le 17/06/2022 à 16:51, Ashley Mort via gdal-dev a écrit :
> We are using GDAL 3.4.1 to convert GeoJSON to ESRI Shapefile with
> ogr2ogr.  Our source data has a datetime field with content like
> “2022-07-09T23:59:59.000000Z” and in the resultant Shapefile it shows
> up as 7/9/2002.
> Is there a way to get the ISO datetime into the Shapefile as a string
> instead of the truncated date?
> Thanks!
> Ashley Mort
> Sr. Software Engineer
> 972-638-6317 office
> 814-571-3039 cell
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220617/9e650b5c/attachment-0001.htm>
