[gdal-dev] convert to ESRI Shapefile- datetime as a string?
Ashley Mort
ashley_c_mort at raytheon.com
Fri Jun 17 20:32:04 PDT 2022
That worked. Thanks!
Ashley Mort
Sr. Software Engineer
972-638-6317 office
814-571-3039 cell
Sent: Friday, June 17, 2022 10:29 AM
To: Ashley Mort <ashley_c_mort at raytheon.com>; gdal-dev at lists.osgeo.org
Subject: [External] Re: [gdal-dev] convert to ESRI Shapefile- datetime as a string?
Ashley,
try adding "-mapFieldType DateTime=String". See https://gdal.org/programs/ogr2ogr.html#cmdoption-ogr2ogr-mapFieldType
You won't get a ISO datetime but the historical format used by OGR: "YYYY/MM/DD HH:MM:SS"
Even
Le 17/06/2022 à 16:51, Ashley Mort via gdal-dev a écrit :
We are using GDAL 3.4.1 to convert GeoJSON to ESRI Shapefile with ogr2ogr. Our source data has a datetime field with content like “2022-07-09T23:59:59.000000Z” and in the resultant Shapefile it shows up as 7/9/2002.
Is there a way to get the ISO datetime into the Shapefile as a string instead of the truncated date?
Thanks!
Ashley Mort
972-638-6317 office
814-571-3039 cell
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220618/bffde10d/attachment.htm>
