[gdal-dev] Weird behavior while reprojecting geometries
Idan Miara
idan at miara.com
Fri Mar 4 03:13:32 PST 2022
On Fri, 4 Mar 2022, 13:12 Idan Miara, <idan at miara.com> wrote:
> Hi,
> Are you familiar with the axis order that was introduced in gdal 3 and its
> affects on 4326?
> https://gdal.org/tutorials/osr_api_tut.html#crs-and-axis-order
> On Fri, 4 Mar 2022, 13:07 Hugo, <hfpmartins at gmail.com> wrote:
>> Hi guys,
>> I'm having weird behavior using ogr and osr through python while
>> reprojecting point geometries.
>> Following code:
>> wgs = osr.SpatialReference()
>> wgs.ImportFromEPSG(4326)
>> etrs = osr.SpatialReference()
>> etrs.ImportFromEPSG(3763)
>> geom = ogr.Geometry(ogr.wkbPoint)
>> geom.AddPoint(-9.10165,38.73981)
>> #geom.AddPoint(38.73981,-9.10165)
>> geom.AssignSpatialReference(wgs)
>> reproj = osr.CoordinateTransformation(wgs, etrs)
>> geom.Transform(reproj)
>> If I run it as it is I get wrong coordinates in the target SRS. However
>> if I switch X,Y when building the geometry (the commented line) I will get
>> the correct coordinates. What is weird is that I have another script
>> reading from geonames dataset and there this behavior doesn't happen.
>> I'm using GDAL 3.4.1 installed through conda on Ubuntu 20.04.
>> Any hints?
>> thanks in advance
>> Hugo Martins
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220304/2fb270b2/attachment.html>
