[gdal-dev] Weird behavior while reprojecting geometries
Hugo
hfpmartins at gmail.com
Fri Mar 4 03:07:01 PST 2022
Hi guys,
I'm having weird behavior using ogr and osr through python while
reprojecting point geometries.
Following code:
wgs = osr.SpatialReference()
wgs.ImportFromEPSG(4326)
etrs = osr.SpatialReference()
etrs.ImportFromEPSG(3763)
geom = ogr.Geometry(ogr.wkbPoint)
geom.AddPoint(-9.10165,38.73981)
#geom.AddPoint(38.73981,-9.10165)
geom.AssignSpatialReference(wgs)
reproj = osr.CoordinateTransformation(wgs, etrs)
geom.Transform(reproj)
If I run it as it is I get wrong coordinates in the target SRS. However if
I switch X,Y when building the geometry (the commented line) I will get the
correct coordinates. What is weird is that I have another script reading
from geonames dataset and there this behavior doesn't happen.
I'm using GDAL 3.4.1 installed through conda on Ubuntu 20.04.
Any hints?
thanks in advance
Hugo Martins
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220304/ce70215b/attachment.html>
