[gdal-dev] crunch lib
chris english
englishchristophera at gmail.com
Sun Mar 6 13:51:23 PST 2022
I defer, though had the opposite experience and the DaemonEngine fork
seemed more recently maintained,
suggested to be the reason for their fork.
On Sun, Mar 6, 2022 at 1:31 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Can you be more explicit of what does not work exactly ?
> - I've just tried https://github.com/DaemonEngine/crunch and it does
> build, but doesn't install headers or a library file, so can't be easily
> used by GDAL
> - I've just tried successfully the build instructions at
> https://gdal.org/drivers/raster/dds.html#build-crunch (for Linux), and
> then managed to build GDAL against it with "cmake ..
> -DCMAKE_PREFIX_PATH=/home/even/install-crunch"
> Even
> > appears to be a better source to point to for crunch, as it builds,
> > whereas crunch link in docs doesn't.
> > And builds for the hapless, as I believe I've demonstrated.
> > Chris
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220306/e74afb2a/attachment.html>
