[gdal-dev] crunch lib
Even Rouault
even.rouault at spatialys.com
Sun Mar 6 10:31:44 PST 2022
Can you be more explicit of what does not work exactly ?
- I've just tried https://github.com/DaemonEngine/crunch and it does
build, but doesn't install headers or a library file, so can't be easily
used by GDAL
- I've just tried successfully the build instructions at
https://gdal.org/drivers/raster/dds.html#build-crunch (for Linux), and
then managed to build GDAL against it with "cmake ..
-DCMAKE_PREFIX_PATH=/home/even/install-crunch"
Even
> appears to be a better source to point to for crunch, as it builds,
> whereas crunch link in docs doesn't.
> And builds for the hapless, as I believe I've demonstrated.
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
