[gdal-dev] VRT dataset to text in-memory?
Michael Sumner mdsumner at gmail.com
Sun Mar 6 20:06:20 PST 2022
Excellent, Even - thanks so much, I have this working now.  I've crafted a
PR for the example.
Mateusz: thank you for the source code overview, I will be using that too.
Best, Mike
On Sun, Mar 6, 2022 at 10:18 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> yes you can get the VRT XML text with:
> poVRTDS->GetMetadata("xml:VRT")[0]
> If you can submit a pull request documenting that, that would be welcome
> Even
> Le 03/03/2022 à 11:14, Michael Sumner a écrit :
> Hello, reading the raster VRT tutorial
> https://gdal.org/drivers/raster/vrt.html#creation-of-vrt-datasets
> with this code:
> int   nBand;
> GDALDriver *poDriver = (GDALDriver *) GDALGetDriverByName( "VRT" );
> GDALDataset *poSrcDS, *poVRTDS;
> poSrcDS = (GDALDataset *) GDALOpenShared( pszSourceFilename, GA_ReadOnly );
> poVRTDS = poDriver->CreateCopy( "", poSrcDS, FALSE, NULL, NULL, NULL );
> Is there a way to obtained the VRT XML text representing poVRTDS without
> writing to an actual file?
> Sorry if this is obvious, haven't been able to find an example that does
> what I want. I've seen examples using GetMetadataItem from a band for parts
> of the XML, but can't see how to get the entire thing.
> Thanks for your help.
> Best, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220307/73213e28/attachment-0001.html>
