[gdal-dev] GDAL 3.4.2 RC2 available
Even Rouault
even.rouault at spatialys.com
Wed Mar 9 12:02:01 PST 2022
Le 09/03/2022 à 20:53, Jeff McKenna a écrit :
> Thanks Even. RC2 works well on Windows in the MS4W build environment.
> The only issue was that I had to re-apply the patch for Poppler 22.x
> (this is the known issue of course, that is well discussed
> https://lists.osgeo.org/pipermail/gdal-dev/2022-March/055529.html )
Which patch did you need re-apply ? The ones of master are normally
included in 3.4.2 :
https://github.com/OSGeo/gdal/commit/2d5f96f233e6bda613e98e056bb9a39d12409e32
https://github.com/OSGeo/gdal/commit/cbcfe2c8c5507ea00ef7371029ff94d0bf6f4a77
. But for nmake based builds, you perhaps need to add a /std:c++17
switch to the POPPLER_CFLAGS variable (PS: the benefit of the CMake
based builds where a single CMake command can be used to bump to c++17
for all platforms is obvious here)
Even
http://www.spatialys.com
