[gdal-dev] CMake and unexpected driver
Even Rouault even.rouault at spatialys.com
Mon Mar 14 13:33:33 PDT 2022
Javier,
> GDAL_USE_ICONV=ON // otherwise it does not compile in Ubuntu 20.04
Fixed per
https://github.com/OSGeo/gdal/commit/b183f2d9eb6c9dd7eefde194ced26d1913c06820
> GDAL_USE_EXPAT=ON
> GDAL_USE_TIFF=ON
> GDAL_USE_GEOTIFF=ON
> GDAL_USE_JPEG=ON
> GDAL_USE_ZLIB=ON
> As you can see, PNG is not enabled. Actually it says:
> -- Disabled components:
>  *PNG component has been detected, but is disabled with GDAL_USE_PNG=OFF
Just a misleading notification message, due to the
GDAL_USE_PNG_INTERNAL=ON being probably set.
Fixed per
https://github.com/OSGeo/gdal/commit/339132cb09c4ba78ffa0b641f298184dcf4f7ab0
Even
http://www.spatialys.com
