[gdal-dev] CMake and unexpected driver
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Mar 14 14:05:51 PDT 2022
Thanks!
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 14 Mar 2022 at 21:33, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> > GDAL_USE_ICONV=ON // otherwise it does not compile in Ubuntu 20.04
> Fixed per
> https://github.com/OSGeo/gdal/commit/b183f2d9eb6c9dd7eefde194ced26d1913c06820
> > GDAL_USE_EXPAT=ON
> > GDAL_USE_TIFF=ON
> > GDAL_USE_GEOTIFF=ON
> > GDAL_USE_JPEG=ON
> > GDAL_USE_ZLIB=ON
> > As you can see, PNG is not enabled. Actually it says:
> > -- Disabled components:
> >  *PNG component has been detected, but is disabled with GDAL_USE_PNG=OFF
> Just a misleading notification message, due to the
> GDAL_USE_PNG_INTERNAL=ON being probably set.
> Fixed per
> https://github.com/OSGeo/gdal/commit/339132cb09c4ba78ffa0b641f298184dcf4f7ab0
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220314/5d8d2600/attachment.html>
