[gdal-dev] CMake and internal json-c
Even Rouault even.rouault at spatialys.com
Tue Mar 15 04:16:33 PDT 2022
if you define both GDAL_USE_JSONC=ON and GDAL_USE_JSONC_INTERNAL=ON, the
use of the internal variant will take precedence. It would be a good
contribution to mention that in https://gdal.org/build_hints.html
Technically, the report is correct: external json-c has been found. But
it is not used. The standard CMake FeatureSummary functionality that is
used doesn't take that subtlety into account. One could possible decide
to remove the external component from the list of detected component
when there's a corresponding _INTERNAL=ON  setting. If you feel it would
be good, please file an issue about that. Bonus point if accompanied
with a patch. The solution would probably to add some code to all
|PACKAGES_FOUND| before the call to feature_summary() (cf
https://cmake.org/cmake/help/latest/module/FeatureSummary.html)
Even
Le 15/03/2022 à 09:20, Javier Jimenez Shaw a écrit :
> Hi
> Keep working with CMake and GDAL_USE_EXTERNAL_LIBS=OFF
> Now I want to enable json-c
> If I do not say anything, I get this message:
> -- JSONC has been found, but is disabled due to
> GDAL_USE_EXTERNAL_LIBS=OFF. Enable it by setting GDAL_USE_JSONC=ON
> If I say
> GDAL_USE_JSONC=ON
> the log message is
> -- Could NOT find JSONC (missing: JSONC_DIR)
> -- Found JSONC: /usr/lib/x86_64-linux-gnu/libjson-c.so
> and later
> -- The following OPTIONAL packages have been found:
> * JSONC
>    json-c library (external)
> Looks like I am doing something wrong, or the "internal" configuration
> is ignored.
> In my computer I have libjson-c installed, but in CI it is not. I want
> to reproduce the same behaviour in both.
> Thanks
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220315/dde068af/attachment.html>
