[gdal-dev] Translate HDF MODIS subdataset get dimensions wrong
inti luna
inti.luna.rsgis at gmail.com
Wed Mar 16 07:48:43 PDT 2022
Hello,
I am trying to read a subdaset from modis total precipitable water product(
https://ladsweb.modaps.eosdis.nasa.gov/missions-and-measurements/products/MOD05_L2).
The specific subdataset is Qualiy_Assurance_NIR.
Checking the file with gdalinfo provide details about subdatasets:
For example:
gdalinfo MOD05_L2.A2013152.0035.061.2017299012514.hdf
Output extract:
SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"MOD05_L2.A2013152.0035.061.2017299012514.hdf":mod05:Water_Vapor_Correction_Factors
SUBDATASET_8_DESC=[2030x1354] Water_Vapor_Correction_Factors mod05
(16-bit integer)
SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"MOD05_L2.A2013152.0035.061.2017299012514.hdf":mod05:Water_Vapor_Infrared
SUBDATASET_9_DESC=[406x270] Water_Vapor_Infrared mod05 (16-bit integer)
SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"MOD05_L2.A2013152.0035.061.2017299012514.hdf":mod05:Quality_Assurance_Near_Infrared
SUBDATASET_10_DESC=[2030x1354x1] Quality_Assurance_Near_Infrared mod05
(8-bit integer)
It can be seen that subdataset 8 has dimensions 2030x1354 which is fine but
subdataset 10 has dimensions 2030x1354x1 which when using gdal translate to
pass it to a geotif gives a raster file with 1x1354 dimensions with 2030
bands which is not right, it should be a file with 2030x1354. What can be
done to correct this or to pass it to the dimensions and match other
subdatasets.
command used to pass it to geotif
gdal_translate
b10_QA_NIR.tif
Thank you for any guidance
Ernesto
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220316/9143de12/attachment.html>
